Does guitar neck/fretboard material affect tone?
mandarin
Post by mandarin » Thu Apr 03, 2008 2:28 am
I don't know if this topic was already discussed before -- i can't seem to find the right keywords for the search criteria (or is it i'm just being simply lazy :P)
do luthiers choose guitar neck's material because it affect tone or it just help in the guitar's playability/structure wear and tear?
it seems that there are only few popular wood choices for neck and fretboard (at least from what i know)
appreciate opinions / expert responses
thanks
Joseph Ramos
Manila, Philippines
Marcus Dominelli
Re: Does guitar neck/fretboard material affect tone?
Post by Marcus Dominelli » Thu Apr 03, 2008 3:38 am
All these things you mention are true.
The neck wood has an effect on the tone for sure. I find that spanish cedar gives my guitars a warmer tone than honduran mahogany. I use both woods depending on what the client wants, and what sound we're after. Honduran m. is lighter weight.
Both of these woods are stiff, and relatively light weight. They have a nice brown colour too, which I like.
I find spanish cedar very hand tool friendly; it's a pleasure to carve.
Maple is not used much by classical guitar luthiers for the neck. It is a very suitable wood though.
Alder, yellow cedar, cherry, walnut, and many more woods would work well too on a classical guitar. But we tend to follow tradition a lot in this trade. The traditional neck woods are getting very scarce, so I think we'll have to soon start using the alternative woods.
Dominelli Guitars
Marcus Dominelli
Post by Marcus Dominelli » Thu Apr 03, 2008 3:43 am
Ooops, I said that Honduran M. was lighter weight, than spanish cedar. I meant to say that Honduran M. is heavier.
The first choice for fingerboards is ebony, and there are not too many alternatives to ebony that I am aware of. Plenty of other woods are hard and heavy enough for fingerboards, but they do not have that nice, neutral black appearance of ebony.
Dominelli "G'tars"
mandarin
Post by mandarin » Thu Apr 03, 2008 4:18 am
thanks a lot Marcus
i appreciate your immediate response :) :) :)
just wishful thinking - it would be nice to find a site with a 3d animation of how the guitar parts move (e.g. how soundboards twist, etc.) while the guitar is being played - this gives a visual appreciation of the physics involving the dynamics of guitar acoustics :D if any of you guys have encountered such a site, i hope we could share it with this forum :)
cheers
Joseph Ramos
Manila, Philippines
senunkan
Post by senunkan » Thu Apr 03, 2008 4:21 am
Sen CL Goh
2013 Sen Goh (S - IR)
2010 Sen Goh (S - IR)
1996 Ross Gutmeier (C - IR)
Alhambra 4P
Yamaha CG110
mandarin
Post by mandarin » Thu Apr 03, 2008 5:27 am
senunkan wrote:Try this site.
http://www.phys.unsw.edu.au/music/guitar/
Sen.
whoah... this is great! thanks alot Sen :)
Joseph Ramos
Manila, Philippines
Alan Carruth
Post by Alan Carruth » Sun Apr 06, 2008 1:22 am
I didn't look all the way through the USNW site just now: there's a lot there! However, from what I did see I don't think they said much about the vibrations of the body below the 'main top' resonant mode pitch. There's one vibration there that involves the neck, and can effect the tone.
You can think of the guitar as a sort of odd-shaped xylophone bar. As with any such thing, the lowest vibration mode is one in which the two ends are always moving in the opposite sense from the part in the middle. In the case of the guitar, the stationary places that demark the 'ends' from the 'middle' (the 'nodes' of vibration) for this lowest vibration mode are roughly at the nut or first fret, and across the wide part of the lower bout. You can hear this vibration if you hold the guitar up by pinching the neck at the first fret or so, deadening the strings, and tapping on the back of the headstock while you allow the instrument to hang freely. You may need to put your ear right up to the surface of the headstock. This is often a low pitched note, and can be around C below the low E. The pitch of this vibration depends a lot of the stiffness and mass of the neck, and the mass of the headstock, and we often call it the 'neck mode', even though the whole guitar is vibrating.
Generally speaking, the 'main air' resonance wil be the lowest pitch mode that can radiate sound effectively. This is often around G on the low E string on guitars, and seldom much below F. The 'neck mode' is, as I say, often lower, and does not by itself usually produce much sound. However, the neck mode can cause the top to belly in and out, and move air through the soundhole. If it is high enough in pitch it will 'couple' with the 'main air' resonant mode. In that case what we see in the sound spectrum is a double peak around the pitch of the air resonance, which will typically be lower in amplitude and broader in pitch than the 'air' peak by itself would be. In a sense, the area under this spectral curve is the 'total available horsepower' in that range, and it's greater when the neck mode is high enough in pitch to couple. The guitar takes on a particularly 'rich' or 'dark' bass tonality, with the notes being even and powerful.
It's hard to 'tune' this mode on a completed guitar. Using a light wood, such as cedro, for the neck seems to help in moving the pitch up. A 'tapered' neck that is deeper at the body end will usually have a higher pitch. The weight of the tuning machines can make a difference, which is one reason swapping out machines can alter the timbre of a guitar. A thick fingerboard might help raise the 'neck' pitch. Carbon or other stiffening reinforcement of the neck can help if it does not add a lot of weight. On one short scale instrument I made, the neck mode was higher in pitch than the air, and I had to add lead weights inside the headstock to 'tune' the neck down. This is unusual: normally ther neck mode is too low, and there's not a lot you can do about it.
