[PDF] Scarlatti, Domenico - Sonata (K.466)
Compositions and arrangements by members of the forum.
III Ours MP3, WMV, MOV, OGG, AVI, Author’s rights
Title format: [PDF/JPG tag] Composer's surname, forename - op.xx/xx Title - tags (if known)
e.g. [PDF] Albeniz, Isaac - op.47 Sevilla
or [PDF] Quantz, J. J. - op.02/02 Duetto - Duo (For more than one forename, just give initials.)
or [PDF] Anon. - Packington's Pound (Use Anon. for all anonymous or traditional pieces.)
Username may replace Composer's surname and forename for your own compositions.
For Giuliani the opus number should be 3 digits (op.048) and for Bach the BWV number should be 4 digits (BWV 0820).
For more details see instructions here.
Intune
Re: [PDF] Scarlatti, Domenico - Sonata (K.466)
Post by Intune » Mon Nov 28, 2016 8:43 am
So glad you like my arrangement, Denian. I hope playing it brings you pleasure.
Allbest,
Intune
Intune
2019 Michael Cadiz (spruce/ziricote)
AO
Post by AO » Tue Nov 29, 2016 2:44 pm
Great job on this and thanks for posting Intune. Another gem added to my library.
I did have to make a few fingering changes to ease my old arthritic fingers though.
Actually, measure 18 I changed the middle note of the triplet to an open E string just to make it flow a little smoother.
Measure 57 -I think you might have meant to have the A in the first beat (middle of triplet) to be played with the 4th finger, that one hurts, the way you have it.
Measure 48 although playable for me I find playing the 3rd beat with 1 and 2 is a bit easier for me, at this tempo swaping fingers is not too difficult.
Cheers,AO.
Intune
Post by Intune » Tue Nov 29, 2016 3:40 pm
Very pleased you like it, AO. I see nothing wrong with changing the fingering if it makes the piece easier for you to play. The fingering indicated suits me and is merely a recommendation, not set in cement. I hope the "old arthritic fingers" feel better soon...
Regards,
Intune
Intune
zoltan
Post by zoltan » Wed Feb 15, 2017 12:06 pm
Hi there,
I'm brand new to classicalguitardelcamp and I tried to download the Scarlatti K466 transcription but i get this message: "You do not have the required permissions to view the files attached to this post." What do I do wrong?
Thanks,
Zoltan
George Crocket
Post by George Crocket » Wed Feb 15, 2017 4:32 pm
Hi Zoltan. Welcome to the forum. You should introduce yourself here and that should solve your problem along with giving you some hints on how best to use the forum.
George
2010 Stephen Eden spruce/cocobolo classical guitar
2012 Stephen Eden cedar/IRW classical guitar
spanishguitarmusic
Post by spanishguitarmusic » Thu Feb 16, 2017 12:06 am
:merci: for this Scarlatti pdf, awesome! :)
Intune
Post by Intune » Thu Feb 16, 2017 12:03 pm
You're welcome, spanishguitarmusic. Glad you like it.
Intune
leonardogarcia02
Post by leonardogarcia02 » Mon Jan 22, 2018 9:28 pm
Hi, Intune,
I was hoping to download your stellar arrangement of K466. For some reason I get a "don't have permissions...
message".
I'm dying to learn it!
Thanks,
Leo
Intune
Post by Intune » Wed Jan 24, 2018 10:28 am
Hi Leo,
Sorry to hear you're having problems downloading the score. Assuming you have Adobe Acrobat Reader, which is required for downloading, it likely is an issue the moderators can help you work through, and I suggest you contact them -- perhaps through a private message -- for guidance.
Glad you like my Scarlatti arrangement.
Intune
Intune
Post by Stephen Kenyon » Wed Jan 24, 2018 11:18 am
It wouldn't be Reader that does the download, only the opening - it probably that Leo hasn't posted enough times to gain access to scores.
George Crocket
Post by George Crocket » Wed Jan 24, 2018 12:37 pm
This is likely correct and should now be resolved.
George
diemaf
Post by diemaf » Thu Aug 30, 2018 10:52 am
Hello to everybody, i listened this Sonata played by Mark Edwards on youtube: i liked it very much, does the partiture of this forum the same played by Edwards? Thanks
Intune
Post by Intune » Fri Sep 14, 2018 8:16 am
diemaf:
After listening to Edwards, I'd say that although the two arrangements are in the same E minor key, they're not carbon copies of each other (some octave differences here and there, etc. etc) -- but on the whole they're quite close. If you haven't heard it already, you can listen to Denian Arcoleo's recording of my arrangement in the "Our Recordings of Early Music" section of the forum. Edwards plays the piece at a slower tempo than Denian and has chosen to ignore the repeat signs.
Intune
jzwi
Post by jzwi » Wed Jun 12, 2019 12:18 am
Intune wrote:
Wed Nov 23, 2016 3:47 pm
Stephen and David, your point is well taken and I'll add sharps to those three notes to avoid confusion. Please alert me if you see any other issues. I'm perhaps too close to the music right now to notice such things and would appreciate a fresh set of eyes looking at it for the first time. Thanks for bringing this to my attention.
Thanks for a nice arrangement and a lot of careful work adding fingerings, string numbers, etc.
After reading through, I only noticed one error - if you are still interested in updating this file:
The bass note B n the down beat of m.62 is labeled with ②, whereas is it should have been labeled with ⑤.
Otherwise, fantastic job.
Schneider
Post by Schneider » Wed Jun 12, 2019 6:19 am
[...] The bass note B n the down beat of m.62 is labeled with ②, whereas is it should have been labeled with ⑤. [...]
Mes.61?... :wink:
Return to “Our scores for classical guitar”
