D02 Classical guitar lesson 09
Post by Jean-François Delcamp » Tue May 01, 2018 7:18 am
Please start by downloading the latest version of volume D02.
First we will study some technical exercises from volume D02.
- page 81 Jean-François DELCAMP (1956) LIAISONS - LEGATURE - SLURS – LIGADOS
Ascending slurs are produced by striking (hammering down on) the string with a left hand finger. The faster and more decisive this movement is, the more volume is obtained.
Descending slurs are produced by pulling the string with a left hand finger (and letting it snap off the fingertip). The more parallel this movement is to the plane of the fingerboard (i.e. towards the adjacent string where there is one), the more volume is obtained.
- page 82 numéro 35 Jean-François DELCAMP (1956) ARPÈGES - ARPEGGI - ARPEGGIOS - ARPEGIOS
In these arpeggios, only your fingers move, be sure to keep your right hand in the same position.
Next we'll work on four pieces :
- page 18 Jean-François DELCAMP (1956) QUATRE ACCORDS
Improvise different patterns of arpeggio and different patterns of accompaniment while keeping strictly to the time signature, key and chords indicated.
- page 61 José FERRER Y ESTEVE (1835-1916) EJERCICIO N°6
Play the melody in the bass with as much legato as possible (without breaks between the notes). Damp the notes of the accompaniment, by placing your fingers on the strings, where indicated by the rests. Try out other fingerings if, in bar 7, you find the indicated fingering difficult for playing the C# and the G. I recommend that you experiment first with the various possible fingerings, (fingers 1 and 2) (fingers 1 and 3) (fingers 1 and 4) (fingers 2 and 3) (fingers 2 and 4) (fingers 3 and 4) until you finally settle on the one that allows you to obtain the best result.
- page 63 ANONYME A CANOA VIROU
In order to mark the beat yourself, you need to count the smallest rhythmic values out loud as you play, as indicated on the score: "1 e 2 e 3 e 4 e" ("1 and 2 and 3 and 4 and" in English)
- page 64 Fernando SOR (1778-1839) LEÇON XV opus 60
Exan qualifying submissions:
QUATRE ACCORDS
EJERCICIO N°6
Tom Wimsatt
EJERCICIO N°6
Tom Wimsatt
Re: D02 Classical guitar lesson 09
Post by Tom Wimsatt » Fri May 11, 2018 2:06 am
First submission. Still a little buzzy at times.
1989 Takamine C132S, Aquila 19C strings
Colin Bullock
Post by Colin Bullock » Fri May 11, 2018 8:40 am
Very good Tom
You could try playing the accompaniment a little subdued to emphasise melody in bass. However, it’s coming along nicely
Tom Wimsatt
Post by Tom Wimsatt » Fri May 11, 2018 11:08 am
Very good Tom
:okok:
Thanks for the feedback. I will work on that.
Tom Wimsatt
Post by Tom Wimsatt » Fri May 18, 2018 2:47 am
:roll: Quatre Accords. ....
Colin Bullock
Post by Colin Bullock » Sat May 19, 2018 10:41 am
A quick reminder of some points for the exam:
Make sure your guitar is in tune
Say your name at the beginning of the piece and make sure your face can be seen at that point.
Keep the tempo as even and accurate as you can - allowing for rubato etc
Make sure your notes are correct without hesitations, try not to get buzzes.
From what I have seen in past years you don’t have to play the piece at full speed to pass, but you will lose marks; and playing slow and plodding or hesitantly will fail you.
When you post your piece make sure you include the text advised:
“Hello everyone,
my name is ............... ............,
I have followed Jean-François Delcamp's online lessons on the English-language forum.
I declare that I have posted on the English-language forum the recordings required for 7 of the lessons at the level for which I am submitting my entry today.
Here is my recording, made without any artificial effects or editing, of the required piece for the year-end exam.”
Good luck and skill
Lucian Bistreanu
Post by Lucian Bistreanu » Sat May 19, 2018 4:55 pm
“Hello everyone,
Good luck and skill
Thank you Colin!
Good luck everybody :)
Tom Wimsatt
Post by Tom Wimsatt » Sun May 20, 2018 1:09 am
Good luck to all the D02 group! It's time to post!
I feel I'm getting to the point where I'm not playing the exam piece any better with repetition.... Plus, I'm starting to drift off task, with spontaneous jumps into "Little Black Egg" and "Goovy Kind of Love" riffs.
I'm probably showing my age here, but I'm cooked.. It is what it is.
Colin Bullock
Post by Colin Bullock » Sun May 20, 2018 5:13 am
It happens to everyone, the brain gets bored and starts to drift. Called plateauing.
If you had the time take a day off or play something else, often plays better afterwards.
Take a break at least.
Hope it goes well
Tom Wimsatt
Post by Tom Wimsatt » Mon May 21, 2018 2:43 am
Second try, worked on bass voice emphasis. Looks like it time to replace that arm band.... - wish I'd seen that.
Ed Butler
Post by Ed Butler » Mon May 21, 2018 11:21 am
Tom - very nice. Enjoyed just closing my eyes and listening.
Ed
Cordoba C7
Tom Wimsatt
Post by Tom Wimsatt » Mon May 21, 2018 2:13 pm
Ed
Thanks Ed :merci: . Thank you for the comment. Thinking about voice emphasis while playing was tough at first. Kind of distracting.
It is easier to not think about what I'm doing while I'm doing it :lol:
Ed Butler
Post by Ed Butler » Mon May 21, 2018 2:25 pm
Very good point. I play golf the same way - totally over analysis everything hence the mind takes over. FYI - something Jules wisely suggested, I am starting with a classical guitar teacher this week. I am hoping to at least smooth out the basics prior to starting level 3 in September.
Ed
Cordoba C7
Tom Wimsatt
Post by Tom Wimsatt » Mon May 21, 2018 2:56 pm
Ed
Ed, I'm very glad to hear your decision to work with a Teacher. I think this is a great idea. Keep in touch over the break, I'm sure you'll do great!
Tom Wimsatt
Post by Tom Wimsatt » Wed May 23, 2018 2:49 pm
This one is driving me nuts.
The sweeping action for the E chord is still hit and miss (i.e. luck). Muting the low E while sweeping the A chord was tricky (but necessary, I could hear it when I tried skipping the mute action).
