La Muerte del Angel (Piazzolla) - how to get velocity on scale
Annalu Braga
Post by Annalu Braga » Sat Aug 11, 2018 9:14 am
Hi, I´ve been in a hard time about 2 years to get velocity in the fisrt big scale (C major in sixteenth notes) in the begining of that piece ( Baltazar Benitez versio, NOT Leo Browuer).
I changed the digitation of LH and RH, im, ami, pami, apoyando e tirando, and never reached a good articulation neither velocity (as far as I got was about 110 on metronome). Have you similar dificult?
Denian Arcoleo
Composer
Re: La Muerte del Angel (Piazzolla) - how to get velocity on scale
Post by Denian Arcoleo » Sat Aug 11, 2018 12:55 pm
Try p,a,i... thumb, ring, index.
Guero
Post by Guero » Sat Aug 11, 2018 9:55 pm
Hi Annalu!
Have you tried to play the scale on different postions on the fretboard?
I play mi, starting the first 3 notes on E string( c,b,a), the next 2 on B string (g,f), and then empty E.
What follows next is just a a-minor scale downwards.
Annalu Braga
Post by Annalu Braga » Sun Aug 12, 2018 10:06 am
Hi Annalu!
Thank you, Guero. Seems to be easier, how fast do you go? Can I see your digitation at this piece cause I have another doubt at the second part.
Guero
Post by Guero » Sun Aug 12, 2018 8:05 pm
Fast enough :wink:
You can also stay on the 5th postion for one more string, i.e. until the b on the 3rd beat (9th note) and then the rest of a-minor.
Just what feels more comfortable for you.
Of the whole piece?! Whivh part are you talking about?
Greetings,
Annalu Braga
Post by Annalu Braga » Sun Aug 12, 2018 9:19 pm
Fast enough :wink:
Greetings,
I´ll try it. The 2nd part. B(5)... A(3) B(0) C(2) D(2) E(0) F(1) are my digitation but I don´t think is the best decision, Thanks.
Guero
Post by Guero » Sun Aug 12, 2018 9:40 pm
?? Sorry, maybe I'm too tired at the moment..
Which bar is it?
Annalu Braga
Post by Annalu Braga » Sun Aug 12, 2018 9:43 pm
3rd bar.
Guero
Post by Guero » Sun Aug 12, 2018 9:54 pm
I need more clues :)
3rd bar from the beginning of the piece?
Annalu Braga
Post by Annalu Braga » Mon Aug 13, 2018 9:56 am
I´ll try to upload this bar.
https://flic.kr/p/29YMmnG
[/quote]
guitarrista
Post by guitarrista » Mon Aug 13, 2018 4:34 pm
I think Annalu means this scale, which is on the third line (8th bar, with a bit from 7th and 9th):
I added the image as it seems it does not violate the rules within paragraph IV for quoting music if it is a short segment.
Konstantin
1982 Anselmo Solar Gonzalez
Annalu Braga
Post by Annalu Braga » Mon Aug 13, 2018 4:45 pm
Guitarrista,
yes, that scale you posted a image and that bar here at this url:
Well, there are two diferent bars:
- First, the scale . My fingering is bad cause I do all the notes descending ( from 1st to 6th strings ) in a parallel movement.
- That bar, is shown how I play, but it´n not a easy way to play.
guitarrista
Post by guitarrista » Mon Aug 13, 2018 4:48 pm
I posted the image because all I see at the flicker site is an image from the beginning of Villa-Lobos's Prelude no.4 (I think), from a Russian book.
Konstantin
Annalu Braga
Post by Annalu Braga » Mon Aug 13, 2018 4:57 pm
Sorry, I´ve changed the url now.
Guero
Post by Guero » Mon Aug 13, 2018 8:28 pm
Ok, let's see..
Now I'm referring to your flickr image which in my edition is bar 20?!
First of all I'm staying on 2nd string except for the A (3rd string) and the last note, open E.
fingering b-string LH: 1 0 I 1 4 4 I__x I 0 1 4 x
fingering a-string LH: 0__I 2___ I 2__I 2____
(The 1st x is A on 3rd string, the 2nd x is open E)
Your fingering would be nice for a slow legato passage. But I think in this case it has to be more snappy.
I hope it's understandable..
At least my 5 centavos:)
Greetings, Güero
