D01 Classical guitar lesson 01
Christopher Langley
Re: D01 Classical guitar lesson 01
Post by Christopher Langley » Thu May 02, 2019 4:02 pm
Paul Cezanne wrote:
Thu May 02, 2019 3:54 pm
Christopher Langley wrote:
Thu May 02, 2019 3:49 pm
That strange marking is called a fermata. Typically it means you can hold the note and extend it.. However in this situation it seems to involves cutting one of the notes short (staccato). If you use your ears you will hear it in the piece. I think maybe the fermata marking is a mistake on the score. To my ears it should be a staccato dot.
I think it is fine there. Try playing that note and instead of counting to 4, count to 5. It gives a nice sense of drama and tension to the part which is immediately resolved when you resume playing.
You are right Paul. I edited my response. I'm actually hearing the staccato note which comes previous to the fermata which interestingly is not indicated.
Over here we sing the song in grade school.. But, maybe a little different than written. I find if I learned it one way it's next to impossible to reprogram. A worthless pursuit. So, I just play it the way I have always heard it!
My Recordings
https://www.youtube.com/playlist?list=PLIXjqRtpseK-33zafCSUfVPpFWHgyh-LZ
Minh-Man Nguyen
Post by Minh-Man Nguyen » Tue May 07, 2019 12:08 pm
Minh-Man Nguyen wrote:
Thu May 02, 2019 2:28 pm
Hi all,
I have some questions about symbol.
Hoping someone will explain for me.
1. What are the numbers and the upside-down bow with a dot insight?
2. Why do we play third string instead second string for note SI?
3. What is the hyphen?
Thank you very much! :merci: :merci: :merci:
The answers to most of your questions would mostly be answered by watching the video of Delcamp playing the piece and by looking at this:
https://en.m.wiktionary.org/wiki/Append ... al_symbols
It's very good to think for yourself. That being said.. It's okay to ask too. We don't mind.
1)The numbers above the staff are keeping track of the bars. The 8 below the treble clef means we play up a full octave from what is written. If you don't quite know what this means. Don't worry.
That strange marking is called a fermata. Typically it means you can hold the note and extend it.. However in this situation it seems to involves cutting one of the notes short (staccato). If you use your ears you will hear it in the piece. I think maybe the fermata marking is a mistake on the score. To my ears it should be a staccato dot. Again, if you don't understand, don't worry. Just use your ears to immitate the piece.
*edit* to my ears there should be a staccato dot on the note before the one with the fermata. And the fermata is fine. I just don't personally extend this note when I play it.
2) Different tone. Different mechanics. Allows vibrato. You can play it where you want, But it will change the tone some. And you can't vibrato an open note. (Easily)
3) Vibrato! (Watch the video)
Cheers. Keep paying such close attention and you will do well.
I just recommend paying more attention to the videos and less to the sheet music and markings.. Probabaly the opposite of what most would say. So, take my advice for what it is.. I'm no expert. I only know the videos really help me immensely. Maybe more than the sheet. Others will feel differently.
Thank Christopher,
I can play what I see in the video but I don't understand why it is played like that.
Thank for your help. :merci:
Colin Bullock
Post by Colin Bullock » Wed May 08, 2019 2:21 pm
Not the opposite, but a different view.
The lessons here are progressive, each building on previous lessons and laying foundations for future lessons, also they are developing different musical skills at the same time.
One of those skills is sight reading. This is an important skill for any musician and it’s good to take any opportunity to develop it. I usually run through a piece as a sight reading exercise before watching the video, sometimes I will only listen to the video once all the way through, other times I will listen carefully to specific parts of the video when there are passages where new ideas are introduced.
Many of the pieces will differ from other versions we may have heard, but it’s important to reproduce what is in the sheet music here if you want to get maximum benefit from the lessons.
Michael McGarty
Post by Michael McGarty » Tue Jun 04, 2019 5:08 pm
Wow, I miss you guys and gals! I dropped out of this class but will register again in September. :cry: Just need to keep at it this time.
Keep playing and practicing!
:chitarrista: :delcamp_ cool: :chitarrista:
Cb = B
Christopher Langley
Post by Christopher Langley » Sat Jun 22, 2019 10:25 pm
I'm still playing these pieces :lol: :roll: :desole: :bye:
My Recordings
Paul Cezanne
Post by Paul Cezanne » Sat Jun 22, 2019 11:28 pm
Hi Chris! I’m almost ready for L6... good to hear from you!
Christopher Langley
Post by Christopher Langley » Sun Jun 23, 2019 12:22 am
Good stuff Paul!
I restart from time to time. :P
My Recordings
