Question about nitrocellulose finish
LBrandt
Post by LBrandt » Thu Oct 11, 2018 7:47 pm
I’ve never owned a guitar with a nitrocellulose finish, but I’m considering a guitar that has a nitro finish, and I have a few questions about such a finish.
I’ve read that a nitro finish never “cures”, and that it’s easily marred. Now, I’m not one that worries about nicks, etc., as I know that a guitar is to be played and not put on display. One or two of my polyurethane finish guitars has the occasional nick, and that’s ok.
My concern is that I’m just wondering about the durability of a nitrocellulose finish, so I’m asking those of you who have guitars with a nitro finish to advise me on the subject.
Thanks,
Louis
Wuuthrad
Re: Question about nitrocellulose finish
Post by Wuuthrad » Thu Oct 11, 2018 9:27 pm
Nitro doesn't scratch as easily as French Polish or Shellac, but it does have a tendency to crack or check over time due to rapid changes in temperature and/or humidity.
Nitro checking is a sought after feature for many guitar players, so much so that you can pay a lot of money for a "weathered" or "antiqued" electric guitar.
Whether or not this is important to a classical guitarist is more a matter of opinion, and not as much a feature of the market.
Nitro is a more durable finish, and may constrict woods' vibration more, although it is not as easily repaired as Shellac. It is originally an automotive finish and has partially contributed to the high gloss feature of guitars.
I prefer it to a Poly finish, but it is environmentally unsafe.
I like the feel of it myself, as it's generally less sticky for my sweaty fingers than Shellac, which I personally cannot stand due to its fragility (as a former Violinist I absolutely prefer Oil Varnish or Tru-Oil,) and I do like the look of a cracked and weathered nitro!
"Pay no attention to what the critics say. A statue has never been erected in honor of a critic." -Jean Sibelius
Echi
Post by Echi » Fri Oct 12, 2018 8:29 am
Nitro is in my favourite finish in terms of tone and is also quite good in terms of future repairability.
The main drawback here is that it’s very unhealthy and this makes it an inconvininient option for the luthier.
The second big drawback is that it is an unstable finish: here in Delcamp Alan Carruth wrote about this aspect quite exhaustively, better you to use the search mode and make reference to him.
Post by petermc61 » Fri Oct 12, 2018 11:29 am
My experience is that nitro and suction cups are a disasterous combination.
Marcus Dominelli
Post by Marcus Dominelli » Fri Oct 12, 2018 3:50 pm
I like nitro lacquer much more than polyurethane, but I still prefer french polish for its ease of repair.
Nitro will react to some plastics, vinyls, and rubbers, if they contact the finish for long.
The first guitar I built was a telecaster copy, which I sprayed with nitro lacquer. I had the guitar stored in a gig bag for a while, and I noticed that the red fluff which formed the nice soft padding inside the gig bag was reacting to the lacquer. It was breaking down the lacquer, and the lacquer was taking on a reddish color.
This kind of thing happens with nitro. It slowly degrades until it's full of cracks, like you see on those old Gibson guitars from the 50's. Lots of character, but french polish can be easily over coated and touched up, so you can keep the finish looking fresh, if not pristine.
Alan Carruth
Post by Alan Carruth » Sat Oct 13, 2018 10:28 pm
Nitro is harder than shellac, so it is 'more durable' in the short term in that respect. In the long run nitro breaks down chemically: it's considered 'toxic' by museum curators because it releases nitrates as it does that ultimately become nitric acid on reaction with humidity and air. Nitro has to be isolated to protect the rest of the collection. Shellac starts out somewhat cross-linked, which makes it less likely to chip or crack than nitro, and shellac becomes more cross linked over time. 'New' shellac is soluble in alcohol and alkaline water solutions, which can include sweat. As it ages it becomes less so, and after 75 years it's insoluble in anything.
Finish chemists keep coming up with harder and harder finishes. Shellac used too be considered a 'hard' finish in comparison with oil varnishes. It was superseded by nitro. Now nitro is considered a 'soft' finish by comparison with UV cure polyester and some others.
Hard finishes add a lot of stiffness, particularly in the cross grain direction on the top. This has got to restrict the movement of the top. Generally speaking, sprayed finishes go on thicker than FP, which adds mass, and that doesn't help either.
If you treat a guitar right there is no reason for the finish to get dinged up. IMO the use of hard finishes on low-end guitars has lead to players not appreciating, or even knowing, the sort of care that a fine instrument should get. There are plenty of hundred year old French polished or varnished guitars out there that look fine because the owners treated them right. In the 'Dangerous Curves' show of guitars as art object several years ago most of the older guitars looked much better than the Martins and such from the 40s and 50s that had nitro finishes.
LBrandt
Post by LBrandt » Sun Oct 14, 2018 1:01 am
Thanks for the information. I'm not a good enough guitarist to be able to tell the difference in sound between poly, french polish and nitrocellulose, so all of my guitars, even the more expensive ones, have a poly finish. But I've read that nitrocellulose never actually "cures", and that's why I've stayed away from it. Maybe the source in which I found that statement was incorrect.
Alan Carruth
Post by Alan Carruth » Mon Oct 15, 2018 1:22 am
Nitro is a solvent release finish, like shellac. You mix the stuff up with the proper solvent and paint/spray/pad it onto the surface. The solvent evaporates and leaves the finish behind. It doesn't 'cure' in the sense that a varnish finish does, by a chemical reaction that changes the nature of the finish. Lacquer thinner is much more volatile than the alcohol that is used with shellac, so lacquer hardens faster. It can still take a few weeks or longer for all of the thinner to be released, but shellac is still slower.
BTW, I'm told that the least toxic thing in lacquer thinner is toluene. That's toxic at a concentration 1/10 of what you can smell. Wear a hazardous vapor mask with a nice fresh cartridge when you apply it. By comparison, if you use pure ethyl alcohol to dissolve shellac the thinner is non-toxic in moderate amounts. Shellac itself is, at worst, inert: you'd get a tummy ache if you ate a lot, but it's not poisonous. They do use it in food as a coating in small amounts, I'm told. The other thing that's used in French polish is oil, often olive oil.
Any finish primarily changes the tone of the guitar according to how much of it there is, and how stiff it is as a material. A very thin coat of almost any finish will have pretty much the same, minimal effect on the sound. One reason FP is so good is that it goes on thinner than most other finishes. Of course, a really thin coating of even a very hard material won't protect the top against dings and/or scratches, particularly if it's a soft wood like cedar. I've been using a very hard and tough oil-resin varnish of late that can be applied only a little bit thicker than FP. It gives more protection, without a noticeable penalty in sound, but it can still be dented easily just because it's so thin. We're talking about a thickness of about .002" (.05mm) for FP, and (with luck) .003" for this varnish. Manufacturers can put on sprayed lacquer finishes at around .005" if they really try to keep it thin; .007" and more is more common. The prize (?) goes to an Ovation guitar I re-topped a few decades back that had .04" (a full millimeter) of epoxy on the top for a finish. You could not scratch it, but the top could not move much to produce sound either. That's the trade-off.
Matthew Masail
Post by Matthew Masail » Mon Oct 15, 2018 9:33 pm
I've been using 'botton lac' for furniture recently. Same stuff as shellac but the process used to make the bottons polymerizes the resin leading to a harder finish. I've had it on my living room table for over a year now with a busy 2 year old using it for everything, it does dent, not as hard as poly, but no doubt much more durable than regular shellac and has no problem with food and drink spills. should be a good choice for guitars.
Jose Marques
Post by Jose Marques » Wed Oct 17, 2018 6:58 am
Hum can you please tell me were to find this botton lack?
I just bougth something called hard shellac from finneys , they garanted me that is more durable to suet of humidity then "normal" shellack.
I plan to use one guitar only back and sides and other all guitar and see if difers or not in sound.
This botton lack probabli is not so hard i dont know, maybe i myst give it a go as well.
The fact is that shellac is my favorite but the player must have allways very carafull with a guitar.
In steel strings guitars i use shellac but i decided to do something diferent, im testing melamine laquer is hard but i aplayed a very thin coat now im wsiting for some days before final steps let see how will work
I'm a Luthier living in Bury st Edmunds UK
Matthew Masail
Post by Matthew Masail » Wed Oct 17, 2018 9:12 pm
I get mine from shellac . net, the golden botton is very nice, the darker shades work nicely to add color or 'patina'.
I've read about the pre mixed 'hard shellac' stuff, I imagine it is even stronger being partly synthetic or whatever but the liquid stuff has shipping restrictions so I haven't been able to try it.
CarbonElitist
Post by CarbonElitist » Wed Oct 17, 2018 9:41 pm
Thanks,
Louis
Basically, nitro is a lacquer.The nitrocellulose, like shellac, is dissolved in a solvent and sprayed onto the surface. As the solvent dissolves, it leaves behind the finish. When people are saying nitro does not cure, what they are talking about is that it takes a long time for all of the solvent to evaporate. As it does evaporate, it will tend to shrink. This is why most companies that supply those "cling on" scratch pads advise against applying them to new nitro finishes. They'll trap the escaping solvent gases and cause checking.
I just received my first guitar with a nitro finish about a year ago and I can tell you it is an easy to scratch finish. Modern nitro is incredibly soft. It's prone to scratches, checking (from weather exposure), and cracks. However, the plus side is that because it is a lacquer, it can be redissolved in its own solvent, which in turn makes it easy to repair. (Or so I've been told.)
EDIT: Alan answered this way better than I did.
"If at first you don't succeed, don't go skydiving."
"When I want expert advice, I look at the comment sections on DIY videos."
LBrandt
Post by LBrandt » Thu Oct 18, 2018 1:08 am
Thanks for all of the replies. I'm still concerned about having a guitar with a nitro finish, since my playing isn't advanced enough such that I would be able to hear the difference between two identical guitars, one finished in poly and the other finished in nitro. If most of you could hear the difference, I applaud you on your playing.
Wuuthrad
Post by Wuuthrad » Thu Oct 18, 2018 3:11 am
In my experience the difference between Nitro and Poly is nowhere near the difference between either of those and Shellac or Oil Varnish.
A Shellac or Varnish will be considerably thinner and less durable, more costly and "sound better" as a result of not constricting the woods' vibrations as much; but if you're shopping between Poly and Nitro, the differences would seem to favor Poly since it isn't toxic and the sound isn't greatly improved by either, whereas they do feel different, i.e. more sticky or more slick, which is up to the individual player really, and Nitro is as stated quite prone to checking.
Alan Carruth
Post by Alan Carruth » Thu Oct 18, 2018 6:56 pm
Aside from the durability of the material itself, the most important thing about the finish is how thick it is. FP is 'the best' because you can make it look nice with a thinner coating. 'Less is more': its more work to do a thin finish than a thick one, and more expensive. A thin polyurethane finish would most likely be better acoustically than a thick finish of a more 'natural' material such as oil-resin varnish or shellac.
