Name that tune
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed.
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed. However, we can say in our posts "you can hear a model interpretation by such and such a guitarist on such and such a site".
This forum serves as a place of mutual help if we are stuck on a technical or musical difficulty, whether the problem stems from the notes, the rhythm, the dynamics, or the fingering. We can post several successive versions of the extract, as our work on it progresses. This will serve to help not only the member who is presenting his work, but also indirectly the dozens of other members who are having the same issues with the same passage, but who don't have the equipment or the technical knowledge to post a recording.
As a rule there should be just one topic per work. If several discussions arise on the same work, the moderators will merge the threads together.
Oudeis
Name that tune
Post by Oudeis » Sun Nov 04, 2018 6:22 am
Hi folks,
I'm trying to identify the title/composer of this piece. Does anyone recognise it?
Much appreciated.
unknown.mp3
ashepps
Re: Name that tune
Post by ashepps » Sun Nov 25, 2018 12:36 pm
Don't know it but I tried tha same thing 3 years ago and nobody recognized it, but the moderator suggested I put it on YouTube, but since I never knew how I never did it, but this may help you?
Good luck,
Alan
Alan Sheppard
1986 630mm Asturias JM-15 Spruce
1955 650mm Framus SL-32R
2015 650mm Yamaha SLG110N
Oudeis
Re: Name that tune
Post by Oudeis » Sat Jun 29, 2019 4:59 am
Well i finally found it, it's an excerpt from Fernando Sor's Fantasy, Opus 4 (Allegretto).
Return to “Extracts of works in progress, 8 bars or 30 seconds maximum”
