Laranjeiras, Quincas - Valsa - Tab
Our arrangements of public domain works or our own compositions for classical guitar as PDF, GIF, PNG ou JPG attachments. These must be tablatures which we have created ourselves, with all necessary care. Since tablature is too imprecise in the expression of polyphony, it is compulsory to include a version in standard notation along with our tablature. Tablatures taken from the internet which we have not produced ourselves will be removed without warning.
Title format: Composer's surname, forename - op.xx/xx Title - Tab - tags (if known)
e.g. Albeniz, Isaac - op.47 Sevilla - Tab
or Quantz, J. J. - op.02/02 Duetto - Tab Duo (For more than one forename, just give initials.)
or Anon. - Packington's Pound - Tab (Use Anon. for all anonymous or traditional pieces.)
Username may replace Composer's surname and forename for your own compositions.
For Giuliani the opus number should be 3 digits (op.048) and for Bach the BWV number should be 4 digits (BWV 0820).
For more details see instructions here.
A version in standard notation must be included.
Marieh
Post by Marieh » Fri Nov 09, 2018 4:59 pm
ashepps
Re: Laranjeiras, Quincas - Valsa - Tab
Post by ashepps » Sun Nov 25, 2018 12:29 pm
This sounds like a great one! thanks again - Alan
Alan Sheppard
1986 630mm Asturias JM-15 Spruce
1955 650mm Framus SL-32R
2015 650mm Yamaha SLG110N
Return to “Our tablatures for classical guitar”
