Rest etiquette?
CarbonElitist
Rest etiquette?
Post by CarbonElitist » Fri Nov 09, 2018 7:34 pm
This is a piece I'm working on. It has two separate melodies/voices going on, but there are long stretches when the first voice isn't doing much of anything. I'm wondering what the etiquette is toward hiding and showing rests?
EDIT: To clarify, this is a piece I am in the process of writing.
And then there are sections in which the second and first voices alternate so much, my program peppers the score with rests and makes it look like a mess. (Or perhaps that's because I'm an amateur at writing music.)
Thoughts/feedback?
Last edited by CarbonElitist on Fri Nov 09, 2018 11:42 pm, edited 1 time in total.
"If at first you don't succeed, don't go skydiving."
"When I want expert advice, I look at the comment sections on DIY videos."
Re: Rest etiquette?
Post by celestemcc » Fri Nov 09, 2018 10:46 pm
Please provide music? I do read TAB, as do many of us, but music would be a lot easier to recognize quickly. If it's a matter of copyright for music, at least tell us the name of the piece -- thanks!
CarbonElitist
Re: Rest etiquette?
Post by CarbonElitist » Fri Nov 09, 2018 11:32 pm
Since most of my guitar-playing friends can only read tabs, that's what I tend to write in unfortunately. However I tried copying the tabs into the score in Musescore. It's a bit of a mess, but it translated fairly well. Since I own the copyright, I'm not too worried about it. :)
Re: Rest etiquette?
Post by celestemcc » Sat Nov 10, 2018 4:12 pm
Well, it's technically correct, but I see your point. Interesting that what doesn't look like a big problem in notation looks like scary in tablature! Not sure what to say. You composed it though, so it's your preference. Perhaps if you just manually add and delete rests as you choose? The transcription program is doing what's "correct" but is that your intent to begin with?
Just as an example: Measure 62the second Bb: there's a perfectly correct 8th rest after it. But is that your intent? Or would you prefer that Bb be a dotted quarter?
I'm sure lots of others will have more insight than I do here. But this is also why I'm a big fan of notation; tab does tell you what to do, but notation tells you everything more clearly, IMO (assuming the editing is good, of course!).
Dirck Nagy
Re: Rest etiquette?
Post by Dirck Nagy » Sat Nov 10, 2018 6:53 pm
First of all, I think you might be overcomplicating things with the tab notation. I don't think its likely that a guitarist who reads only tab would notice rhythmic subtleties such as the 8th rests in the lower voice, if you did intend for that line to have such a "detached" character. I'd consider simplifying the rhythmic values...?
But, if you want to actually notate the piece, there are some general notation conventions to be aware of. One very important one is to show the middle of the measure (and also the middle of the beat unit, usually)
For example:
[*]m.48: rhythmic group for upper voice should be:
Usually, you should try to show the middle of the beat unit, too.
[*]m.57 would therefore look like this, instead of the quarter rest between beats 1 and 2:
If you go through your piece, you will see several other places where these issues occur.
There are also inconsistencies in your 5/4 measures. Are these measures divided 3+2 or 2+3?
If they are 2+3, m.53 could look like this:
If they are 3+2, m.53 could be:
Interestingly enough, the rests aren't consistent bewteen the tab and notation versions! (see m.54 and 57) I wonder why MuseScore did this when you converted the file?
I hope this helps!
cheers
dirck
Dirck Nagy
Re: Rest etiquette?
Post by Dirck Nagy » Sat Nov 10, 2018 7:02 pm
Sorry, I just re-read this post.
Regarding the long stretches of full-measure rests: different publishers have different "style sheets". Some might notate the whole-rests on the first 4 measures, others might not.
(in any case, the whole rest should be on the top line of the staff if there is a lower voice present, not above the staff)
CarbonElitist
Re: Rest etiquette?
Post by CarbonElitist » Sat Nov 10, 2018 7:07 pm
Nah, that was human error. Between the time I posted this topic and the time Celest asked for a score, I went and changed some of the rests.
I hope this helps!
cheers
dirck
I'm afraid I didn't take any classes on how to write and arrange music, so naturally anything I transcribe is a mess. :lol: Thanks a lot for your feedback, I'll have to pore over it a bit. Could you elaborate a bit on what you mean by "showing the middle of the measure"?
2lost2find
Re: Rest etiquette?
Post by 2lost2find » Sat Nov 10, 2018 8:24 pm
If you look at measure 48 you have a single quarter note that goes across beats 2 and 3. That's a no no; it should be two tied 8th notes so the middle of the measure is clearly visible.
Re the original question: It's a preference thing, really. I would probably skip the rests for the long stretches where there is nothing in a voice just to make the notation cleaner.
CarbonElitist
Re: Rest etiquette?
Post by CarbonElitist » Sat Nov 10, 2018 8:40 pm
Much appreciated! I wasn't aware of this convention. I'll do what I can and show what I have later. Thanks for the help!
Mark Clifton-Gaultier
Re: Rest etiquette?
Post by Mark Clifton-Gaultier » Mon Nov 19, 2018 2:29 pm
CarbonElitist wrote: ...I didn't take any classes on how to write and arrange music ...
It's easy enough to learn through reading. Try looking up Standard Music Notation Practice from the Music Publishers' Association (MPA). It's an American, not European standard - I don't know where you are located.
For reader ease and comfort one should also attempt to follow the guidelines regarding music spacing, vertical rest positioning, accidental placement etc.
Don't forget that a "rest" indicates silence. Is that what you intend - in the bass beginning at measure 49 for instance?
Advice is spelled (or spelt) with a c, not an s by the way.
