D04 Classical guitar lesson 05
Post by Jean-François Delcamp » Tue Jan 08, 2019 8:43 am
Please start by downloading the latest version of volume D04.
We are now going to work on a series of exercises:
- page 114 numbers 17, 18, 19 - Jean-François DELCAMP (1956) GAMMES - SCALE - SCALES - ESCALAS
The following videos correspond to numbers 17, 18 and 19 on page 114. Concentrate your practice on the passages highlighted in yellow, working to perfect the technique of position-shifting up and down the neck.
- page 124 Delcamp, Jean-François ARPÈGES - ARPEGGI - ARPEGGIOS – ARPEGIOS
Finally we'll look at 5 pieces, pages 22, 54, 55, 56, 57, 78, 79 and 88.
- page 22 Dowland, John Mistris Winters Jumpe
Here we have a "jig". 6/8 time has two beats to the bar. The strong beats are on the first and fourth quaver (eighth note). The phrase structure (see previous lessons) is of 4 bars. Bars 5 to 8 are a division (see lesson D04 n°3) on bars 1 to 4. The 3rd phrase finishes in bar 12 with a half cadence (imperfect cadence), that is one ending on the dominant. The piece concludes with a slightly modified repetition of bars 1 and 2.
http://en.wikipedia.org/wiki/Cadence_(music%29#Half_cadence
- page 54, 55 Sor, Fernando Exercice opus 35 n°22, en si mineur, Segovia n°5
The phrase structure is of 8 bars. This study is a polyphonic composition in three voices. At the beginning we have the impression of hearing just a single voice. In the first section, the times when you play two notes together are rare: the 1st beat of bars 1 and 9, and the 3rd beat of bar 13.
The polyphony is only fully expressed from bar 25, when the range of pitch (also known as ambitus or compass *) becomes wider and the bass notes start to appear on the first beat of the bar.
The rest stroke is well suited to bringing out the melody (the upper voice). Use the free stroke to play the accompaniment. In this study, from the beginning to bar 24, the melody takes place within a narrow range (a fifth). This narrow range calls for a low volume (mezzo piano or mezzo forte). From bar 25, the range becomes wider, calling for the fullest sound from the guitar, with an assertive volume (forte). From bar 33, go back to the mp or mf level. From bar 41 to the end, the range becomes wider again, so go back to a more powerful volume. Reduce the volume of the last two bars gradually to conclude the study mezzo piano.
- page 56, 57 Sor, Fernando Valse opus 51 n°3
The phrase structure is of 8 bars. In this waltz, the melody of the first section, in E minor, takes place within a narrow range. For this E minor section, I advise a restrained articulation: "non legato" or "mezzo staccato" or maybe "portato".
http://www.dolmetsch.com/musictheory21.htm#accent
The range becomes wider in the second section in E major. In this E major section, the guitar is required to give its fullest sound with an assertive volume. For this section I advise a legato articulation.
- page 78, 79 Paganini, Niccolò Perigoldino
There are many repetitions, so vary the tone colour to avoid monotony.
All the phrases start with an anacrusis (pick-up note or upbeat) on the 4th crotchet (quarter note). All the phrases end on the first crotchet (quarter note) of a bar.
The piece is in the key of A, and this key allows the 3 bass strings of the guitar to be used to their best effect: E (dominant) A (tonic) D (subdominant). Observe the precise length of the bass notes, and damp them by placing your thumb on the open string.
- page 88 Tárrega, Francisco Estudio, en mi minor
Another piece in three voices. Here again I recommend that you use rest stroke for the melody (upper voice). The right-hand fingering is based on the most classic principle: the ring finger plays the first string, the middle finger plays the second, and the index finger plays the third, while the thumb plays strings 4, 5 and 6. To practise this type of fingering, see the arpeggios of Mauro Guiliani, pages 130 and 131 of volume D04.
Mauro Giuliani was the first teacher to publish a systematic study of arpeggios (http://www.guitareclassiquedelcamp.com/ ... liani.html : Opus. 1 - Studio per la chitarra, Prima parte : 120 arpeggi).
I recommend that you practise a few arpeggios each day and change them regularly with the aim of studying all of them in two years. You can hear the mp3s of the 120 arpeggios recorded by Marco Cairone here: http://www.chitarraclassicadelcamp.com/ ... 32&t=25253 .
