Lute Isabelino e - b a y problem with G4-string
Discussion of all aspects of early instruments, lutes, theorbos, vihuelas, Renaissance guitars and Baroque guitars.
Luteagent
Post by Luteagent » Fri Jan 18, 2019 2:36 pm
My Lute Isabelino, which I bought on e - b a y last week has finally arrived, but there ist a problem with it:
I can`t fix the G4 String because the peg of the G4 string does`nt hold tight.
I think this is not ok and will aks the seller for a massive reduction or send it back to him.
Or are there other solutions?
Andreas
Re: Lute Isabelino e - b a y problem with G4-string
Post by Michael.N. » Fri Jan 18, 2019 2:50 pm
Try chalk on the areas of the peg that contact the peg wall. If that doesn't solve it then it could be a peg that has been badly fit. Peg paste for sticking pegs, chalk for pegs that slip.
Kent
Post by Kent » Fri Jan 18, 2019 2:57 pm
This is not a major issue, and if you like the instrument and the price was right, keep it!
I think it would be unfair to expect a "major reduction" in the price of the instrument.
Post by simonm » Fri Jan 18, 2019 3:10 pm
Learning how to service the pegs is part and parcel of playing a lute. If you know any violin/viol/cello player they might be able to give you are quick intro. I wouldn't consider it a major issue. It might have been nice if the seller mentioned it, but it is also a fair assumption that anyone buying any instrument with pegs will have some knowledge about how they work.
Luteagent
Post by Luteagent » Fri Jan 18, 2019 4:40 pm
Many thanks for your advices!
I have spoken with the seller now and he just told me, that I have to fix the problem with peg paste.
Fortunately I have a Lutespecialist near my home, and I will visit him tomorrow, so that he can solve the problem with the pegs.
Andreas
Luteagent
Re: Lute Isabelino problem with G4-string
Post by Luteagent » Sat Mar 02, 2019 2:05 pm
While I play my new lute for six weeks now, a new problem with the G4-string has appeared.
The G4-string has broken two times in six weeks now, although I don´t play more than 15 minutes per day.
Is that normal?
Andreas
Post by pogmoor » Sat Mar 02, 2019 3:11 pm
What strings are you using and where in the string have the breaks occurred?
Luteagent
Post by Luteagent » Sat Mar 02, 2019 3:30 pm
I use Pyramid strings for lute. The breaks occurred in the lower part of the string.
Andreas
Return to “Lutes, Baroque and Renaissance Guitars, etc.”
