Help with Lilypond string number indication
Trystramys
Post by Trystramys » Sun Jun 10, 2007 10:11 am
Hello all,
I just got into Lilypond today, and after a bit of experimenting, I've found it to be very fun and extremely straightforward. I've learned the basics, but I'm having trouble with adding string number/letter indications. Fingering numbers are alright, but STRING number indications don't show up.
The website documentation mentions that one should add a "\" and the string number after the note, but that doesn't seem to work. Am I missing something?
Any help is appreciated. :D
Garlik
Post by Garlik » Sun Jun 10, 2007 3:29 pm
Hi Tristramys,
<e-3\3>4.
<d-1\3>8
:wink:
camytay
Post by camytay » Sun Jun 10, 2007 6:20 pm
Does this Lilypond run on Windows without any problems?
Trystramys
Post by Trystramys » Mon Jun 11, 2007 12:15 am
Garlik, it works! Thank you so much! :okok: It's just a matter of getting the right syntax. :roll:
Cam, it runs without any problems for me (WinXP). If you've dabbled with programming language and you're comfortable working without a GUI, I recommend you try it! :D
wolfgang
Post by wolfgang » Mon Jun 11, 2007 8:12 am
Thanks for the question and answers :wink: And if you folks have some sheets ready, would you share the sources as well? I'd like to see some sheets with guitar-specifics incorporated....
Greets
Wolfgang
Trystramys
Post by Trystramys » Mon Jun 11, 2007 9:52 am
Welcome back Wolfgang! :D
As for samples, here's a couple I've been dabbling with. Notice in the second sample that I haven't quite gotten the spacing right. I'll work on that later. :roll:
As for the source code, I did what Garlik suggested: left hand fingerings are indicated with a -number (ex: f-1); string numbers with \number, plus the chord brackets if you add fingerings, etc (ex: <d-4\3>16).
There are more guitar specifics here:
http://lilypond.org/doc/v2.10/Documenta ... ond/Guitar
Just be careful with whitespaces. :D
camytay
Post by camytay » Mon Jun 11, 2007 10:44 am
Trystramys wrote: Cam, it runs without any problems for me (WinXP). If you've dabbled with programming language and you're comfortable working without a GUI, I recommend you try it! :D
I do have a little light programming experience (php) but I think I'd still fancy a nice clickable GUI for making music sheets.
Garlik
Post by Garlik » Mon Jun 11, 2007 11:08 am
Have some .ly here if some want to get my crappy works but also you can try http://www.mutopiaproject.org/.
BbMinor
Post by BbMinor » Mon Jun 18, 2007 11:15 pm
I downloaded LilyPond today and experimented a bit with it. (On Sor, Op. 60, No. 1)
The results of this program are pretty awesome!
The music sheet is so... pretty! :D
(sor_60_1.ly, sor_60_1.pdf)
Jouni Stenroos
Post by Jouni Stenroos » Tue Jul 31, 2007 10:09 am
I have used my own macros to create string numbers.
Code: Select all
gsone = \markup { \circle \teeny "1" }
similarly gstwo, gsthree etc. The definitions can be placed in a separate file which then can be included using the \include statement.
Using them is done exactly like other text markups, putting it after a "-" places it either above or below, depending on the note, using a "^" or "_" instead forces it either above or below.
Code: Select all
c4-\gstwo d-\gstwo
/Jouni
musikai
Post by musikai » Tue Jul 31, 2007 10:17 pm
It's no gui but here you can get a very good addon for the texteditor Jedit.
http://lilypondtool.organum.hu/
Features:
- Document Wizard with lyrics support to set up documents easier
- Point-and-click support
- Structure browser with code folding
- Simple parser for finding simple errors
- Convenient running of LilyPond and related tools
- Automatic code completion for typing commands and tweaking properties
- Automatic hyphenation of lyrics using OpenOffice dictionaries
- Tools for macro and template writing
