Software for guitar notation
Gerry
Re: Software for guitar notation
Post by Gerry » Fri Apr 25, 2008 12:30 am
P.S. I posted a duet version of Plaisir d'Amour made with Finale at
viewtopic.php?f=12&t=27963&p=280975#p280975
I'm quite happy with the output (although not professional standard). There were no problems with placing those merged note heads. There are two independent voices in a couple of places. Also, the reverse stems technique at measure 44 worked well.
Gerry
Larry McDonald
Post by Larry McDonald » Fri Apr 25, 2008 5:31 pm
Hi Gerry,
Gerry wrote:The only thing I can't see how to do for CG is the notation with numbers inside a circle to show the left-hand position.
Click the expression tool.
Double Click the note that you want to identify with a string. The expression selection window opens.
Click create. Type in the string number. (Under text drop down menu, you can change the size/font).
On the text expression designer window, you will see an enclosure option. Click on the arrow and choose circle.
Choose edit to resize the cirlcle to taste.
Click OK.
Click Select.
All of the examples on my site were done this way. See the B Major scale on the student's page.
http://www.larrymcdonaldguitar.com
You should be good to go.
Larry McDonald
xcal
Post by xcal » Sat Apr 26, 2008 3:54 am
MusEdit, MusEdit, MusEdit. 'nuff said
This is very easy to do in MusEdit, which, as has been said, has wonderful guitar support - but its not just for guitars. I've done multiple instruments, including percussion, as well as music with lyrics. And, very, very reasonably priced. And there is a recent upgrade (Apr 2008) (always free, I believe, for registered users). I find creating a page of music very fast. There's a keystroke for just about everything, so you can bypass the mouse if you want. There's swingtime; tab with rhythm; guitar chord charts - lots of features.
Gerry
Post by Gerry » Sat Apr 26, 2008 12:15 pm
Lare wrote: You should be good to go.
Thanks for your explanation Larry. The method works well.
If I could ask you one other thing, do you know how to use Finale to handle that problem I asked about in the first post in this thread - i.e. if I try to superimpose a half note over a note with a black head such as a quarter note, the black shows through, so the note no longer looks like a half note. Is there a way overcome this, without having to modify the quarter note to hide its head?
Your advice is much appreciated.
Gerry
Larry McDonald
Post by Larry McDonald » Sat Apr 26, 2008 2:29 pm
Hi,
I usually write a rest with a stemlet in the top part so I don't use this notation style. See an example at the bottom of this post. I think this is the modern way of solving this notation oddity. I use ties when I want the note to continue and use rests when I want the upper part to be silent. This way there is no confusion as to duration. This avaoids the original problem entirely.
The tutorial says that you can change note heads, and then copy to another measure. I suppose if you put the subdivided part in one layer, erased the note head, and then wrote the other layer, this would be fast. Here is the Finale 2008 instructions.
Note shapes
A notehead can be any shape in Finale, including X, diamond, square, circle, slash—you can even create invisible noteheads. You can globally define noteheads to be a particular shape on the basis of rhythmic value, position on the staff, or both. You can also change individual noteheads to any shape.
To change the shape of a notehead
From the Window Menu, choose Advanced Tools. Click the Special Tools Tool , and click the measure in question.
Click the Note Shape Tool . A handle appears on each notehead.
Double-click the handle of the notehead you want to change. The Symbol Selection dialog box appears, displaying every character in the music font.
Double-click the desired replacement notehead shape. To restore the notehead to its original shape, click its handle and press delete.
To copy individual notehead changes to other measures
If you require a more global note shape configuration that can’t be addressed by changing all notes of a specified pitch and duration to a specified shape (see “To change all notehead shapes of a specified duration and pitch”), you can create the changes manually and then paste only the note shape information onto other measures.
Change the notehead shapes manually in the first measure or measures. See “To change the shape of a notehead.”
Click the Selection Tool , and select the modified measure or measures. See Selecting music for some region-selecting shortcuts.
From the Edit Menu, choose Edit Filter. A dialog box appears, listing elements of the music that you can copy individually.
Click Notehead, Accidental and Tablature String Alterations. Click OK.
Drag the first highlighted measure so that it’s superimposed on the first target measure. If the target measure isn’t visible on the screen, scroll until it’s visible, then ctrl–shift-click it. Unless the target measures are directly above or below the source measures, the “How many times?” box appears.
Enter the number of times you want the notehead shape information copied. Click OK (or press enter). To restore the noteheads to their original shapes, select the region using the Selection Tool. Choose Clear Items from the Edit Menu. Proceeding through the dialog boxes, click as follows: Only Selected Items; Entries; Notehead, Accidental and Tablature String Alterations. Click OK (or press enter) twice.
This technique is especially useful for Shape Note Music, where the shape of a note indicates its pitch, and for drum parts, where you might want all notes on the spaces of the staff to have X noteheads (cymbals and hi-hat), but all notes on lines of the staff to have normal noteheads (tom-toms and bass drum).
You can assign a different notehead shape to each step of the scale.
Click the Staff Tool ; then double-click the staff in question. The Staff Attributes dialog box appears for the staff you clicked. You grant permission for changeable note shapes one staff at a time.
Under the heading Independent Elements, select Notehead font; then click Select. The FontFont dialog box appears.
Select the font, and size of the Notehead you want to use, then click OK. For Shape Note music or percussion noteheads, use Maestro Percussion or JazzPerc.
Select Note Shapes from the Notation Style drop-down menu,
Click on the Select button next to the Notation Style drop-down menu, The Note Shapes options appear.
From the drop-down menu, choose the first notehead shape you want to change. The four basic note shapes in Finale are the quarter notehead (also used by eighth, sixteenth, and smaller note values), the half notehead , the whole notehead , and the double whole note. For each note of the scale, you can specify an alternate notehead shape (X, diamond, and so on) for each of these four basic shapes. For example, you could specify that every half note occurring on the third scale degree will appear as an X notehead. See Shape Note music for a chart of note shapes and scale degrees.
Specify the scale degree for which you want to modify the selected notehead. Enter the scale degree into the “scale degree” text box, or click the up and down arrows until the scale degree number is the one you want.
Click Select. The Symbol Selection dialog box appears, displaying every character in the music font.
Double-click the symbol you want to serve as the alternate notehead shape. You can continue this way, using the arrow buttons to move through the scale degrees, and clicking Select to choose a new notehead shape.
Click OK twice. You return to the document, where the noteheads of the type and scale degree you specified have automatically changed to the alternate note shapes you selected. If you anticipate creating other scores with the same configuration, save this piece on your disk as a template (a blank document without any notes in it), so that you won’t have to repeat the process the next time you need to create alternate note shapes.
All the best,
Larry McDonald
Gerry
Post by Gerry » Sat Apr 26, 2008 9:46 pm
Lare wrote:Hi,
Again, many thanks Larry. I've just update to Finale 2008 from 2001, and there are quite a few differences. Your example looks like a good way to solve the notation problem - although, personally, I like the economy of the appearance of the merged notehead style.
Best wishes
Gerry
jack_cat
Re: MusEdit Open Source Development??
Post by jack_cat » Fri Jun 21, 2019 7:58 pm
There were a lot of MusEdit users in this ancient thread. I still use it myself. Some years ago the programmer, Doug Rogers, threw up his hands and released it for free, saying that it would now be "open source". Although the program is still available, for free, and still runs on Windows 7 (at least) I have never seen any source code released. Anybody ever found any? I think he said it was done in C++.
The one feature that could most be improved in MusEdit is the horizontal width of the individual cells, which are fixed. If it were possible to select a group of cells and adjust them to a particular width in pixels, the horizontal space consumed by different note values such as groups of 16ths versus half notes, or whatever, could be proportionally adjusted, and the output improved. If I could get my hands on the source code, maybe I could then find somebody capable of addressing this.
Arion Romanus
Post by Arion Romanus » Fri Jun 21, 2019 8:31 pm
Ever tried MuseScore? It's open source and under active development, and I'm sure it can already do what you want. I realize it's not ideal to switch from something you've used for so long, but if you're at the point where you're willing to start fixing the program yourself, perhaps making the switch would actually be less effort.
Schneider
Post by Schneider » Sat Jun 22, 2019 7:19 am
Hi jack_cat,
See also: viewtopic.php?p=623591#p623591
Pierre
jack_cat
Post by jack_cat » Sun Aug 04, 2019 1:01 pm
Ever tried MuseScore? It's open source and under active development, ... perhaps making the switch would actually be less effort.
You have a point, thanks.
Hi jack_cat,
Pierre
No source code there! I think maybe Doug Rogers never actually released any source code,
for all he said that he was going to make it open source.
Maybe he had second thoughts about that.
