D03 Classical guitar lesson 4
Post by Jean-François Delcamp » Tue Jan 25, 2011 5:07 pm
Please start by downloading the new version of volume D03 that I updated today.
- page 89, numbers 13, 14, 15 - Jean-François DELCAMP (1956) GAMMES - SCALE - SCALES – ESCALAS
The following videos are for numbers 13, 14, 15 on page 89. Concentrate your practice on the passages highlighted in yellow, and do your best to perfect the position shift technique.
- Page 94, numbers 29, 30, 31. Jean-François DELCAMP (1956) LIAISONS - LEGATURE - SLURS – LIGADOS
We have already worked on the rest stroke (apoyando) with the fingers of the right hand. Now we are going to work on doing a rest stroke with the fingers of the left hand. That is the best way to learn how to execute descending slurs. In number 30, bar 2, the fingers of the left hand execute the slurs with the help of the rest stroke. The fingers 4, 3, 2 and then 1 pluck the second string then finish their move by coming up against the first string. Place the left hand fingers vertically in relation to the fingerboard, that's the right position to play slurs.
Finally, we'll look at 3 pieces, pages 14, 30, 46 et 47.
- page 14 Francis CUTTING (ca. 1600) PACKINGTON'S POUND
There are numerous repetitions, so vary the tone colour to avoid monotony. To obtain different tone colours, play:
- over the soundhole (the sound volume is at its best here and you get a good balance between the bass and treble notes);
- over the fingerboard (the sound here is softer, closer to the that of a clarinet, and the basses are softened);
- near the bridge (the sound here is more metallic, and becomes close to that of the harpsichord, the basses are strengthened and the trebles weakened).
- page 30 Gaspar SANZ (1640-1710) SALTAREN
This dance will serve as a basis for improvisation work proposed in lesson N. 7. The sequence of the three following chords: D Major, G Major, A Major requires imagination to avoid monotony. In order to avoid monotony use dynamic changes (fortissimo, forte, piano, pianissimo), different sound colors (sound hole, fingerboard, bridge, with nail, no nail) and different strumming styles: rasgueados, plucked chords, arpegiated to the bass or treble, etc … .
- page 46-47 Ferdinand CARULLI (1770-1841) ANDANTE
This piece consists of three sections, the third section being identical to the first, so it has an A-B-B-A structure, also called ternary form.
Vary the tone colour to avoid monotony.
I advise you to work on all the exercises and the four pieces for a week. From February 1st, please record and upload your recordings of the following:
I thank Eric (wchymeUS) and Geoff (GeoffB) who have helped in the translation of my lessons into English.
Jeremy Hickerson
Re: D03 Classical guitar lesson 4
Post by Jeremy Hickerson » Tue Jan 25, 2011 8:19 pm
From January 11th, please record and upload your recordings...
I assume this date will be corrected?
Jeremy
Post by Jean-François Delcamp » Tue Jan 25, 2011 8:37 pm
yes :D
it's done (February 1st)
:merci:
RicDavalos
Post by RicDavalos » Sat Feb 05, 2011 8:19 pm
Hello all,
Here's Packington's Pound. I stumbled around measures 12 and 13, sometimes I hit it sometimes not. It'll take more practise.
[media]https://youtu.be/cUhLephU7xc&feature=youtube_gdata_player[/media]
I'm still working on Carulli's Andante. I'm working on getting the damping better and the overall rhythm smoother.
Cheers
Greg Johnson
Post by Greg Johnson » Sun Feb 06, 2011 5:42 am
Ric, You're a quick study, I thought that was very good. I'm not quite up to tempo yet but I am enjoying learning this piece.
QadirASabur
Post by QadirASabur » Sun Feb 06, 2011 4:28 pm
HI Ric,
I agree with Greg, that was very good.
Julio Galindo
Post by Julio Galindo » Sun Feb 06, 2011 7:05 pm
:bravo: Ric!
Very good sound and great picture quality by the way.
I just posted Lagrima in youtube and some other pieces I´ve been working, but i hope i can turn in my homework sometime this week.
cheers
Leonardo Silva
Post by Leonardo Silva » Sun Feb 06, 2011 9:36 pm
Good job Ric. I really liked your interpretation. :bravo:
Here is my first try on Francis CUTTING (ca. 1600) PACKINGTON'S POUND. Its what i said, my first try, so its not quite good already. I'll be trainning this one specially because of the damping stuff. Damping really turns the pieces harder to play.
This time i just recorded the audio. My digital camera isnt working properly...
RicDavalos
Post by RicDavalos » Mon Feb 07, 2011 10:39 pm
Thank you all for the comments.
Thanks Julio. I used my i Phone 4 to record the video and I used my bose headset for the microphone which I clipped as close as possible to the guitar.
Leonardo. Good job on on Packington's Pound. It's better than what you give yourself credit for.
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 13, 2011 6:28 am
Here's my two posts:
Saltaren
[media]https://youtu.be/4a6sXm53KwM[/media]
Packington's Pound
[media]https://youtu.be/u23FeP-ppQA[/media]
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 13, 2011 6:36 am
Ric,
Very nice on Packington's Pound - extremely clear, even and lively tempo, good musical feel overall! A pleasure to listen to.
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 13, 2011 6:43 am
Leonardo,
There are parts of your Packington's Pound where it really comes together and sounds just like something you'd hear on the radio or a similar professional setting - you really have something going well here rhythmically, and in phrasing and dynamics. True there are other parts that still need polishing, as you said.
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 13, 2011 7:09 am
Julio,
Nice job on Lagrima, and on the Scarlatti piece and especially the beautiful sonorous Barrios! Everyone, you should check this out on Youtube, look for jcmusicpro.
I have also done some other stuff on youtube under jeremyhickersonsalem.
Jeremy
Leonardo Silva
Post by Leonardo Silva » Sun Feb 13, 2011 10:24 pm
Thanks Jeremy for you comments. Keeping the rithm for the entire piece is one of my great dificults. I always tend to accelerate some parts. Well, it should be expected on a Heavy Metal fan... :casque:
Jeremy Hickerson
Post by Jeremy Hickerson » Mon Feb 14, 2011 4:24 am
rock on!!
Jeremy
