D04 Classical guitar lesson 04
Post by Jean-François Delcamp » Sat Dec 17, 2011 8:14 am
Please start by downloading the new version of volume D04 that I updated today.
- page 113, numbers 14, 15, 16 - Jean-François DELCAMP (1956) GAMMES - SCALE - SCALES – ESCALAS
The following videos are for numbers 14, 15, 16 on page 113. Concentrate your practice on the passages highlighted in yellow, and do your best to perfect the position shift technique.
Finally, we'll look at 4 pieces, pages 26, 62, 63, 76, 77 et 98.
- page 26 Anonyme Scarborough Fair
The phrase structure is of 4 bars. (Phrase structure is the division of the larger musical phrase into parts of equal length, with the most common division being into sections of 4 bars. This division is linked not only to walking, but also to dance, poetry and singing.) Here we have an English tune dating from the end of the Middle Ages. The accompaniment in eighth notes (quavers) gives a fluidity to the whole. It's enough to accentuate the notes of the melody slightly for "Scarborough Fair" to evoke a feeling of space and peace. I think this piece has strong therapeutic powers both for us playing it and for those listening.
- page 62, 63 Giuliani, Mauro Etude opus 51 n°12
In this arpeggio study, the melody is in the bass. The index and middle finger play the accompaniment on strings 1 and 2, while the thumb plays the melody on strings 3, 4, 5 and 6.
The point of this study is to seek to keep the index and middle finger strokes of equal strength throughout, whether the distance between them and the thumb is small (when the thumb is playing string 3) or large (when the thumb is playing string 6).
From bar 20 onwards, the instruction sf (sforzando, sforzato, sf, sfz ) means that you should give a sudden, strong emphasis to the note immediately above the instruction.
In bar 22, I use a hinged barré (indicated by a dotted line instead of a solid line) to play the D and A on the open strings, and I don't apply the full barré until the third beat of the bar, to play the bass Bb.
Mauro Giuliani is the first teacher to have published a systematic study of arpeggios ( http://www.guitareclassiquedelcamp.com/ ... liani.html : Opus. 1 - Studio per la chitarra, Prima parte : 120 arpeggi). I recommend that you practise a few arpeggios each day and change them regularly with the aim of studying all of them in two years. You can listen to the mp3s of the 120 arpeggios recorded by Marco Cairone here: http://www.chitarraclassicadelcamp.com/ ... 32&t=25253 .
- page 76, 77 Paganini, Niccolò Ghiribizzo n°24
Ghiribizzo n°24 is in two sections, each of 20 bars. It has a phrase structure of 4 bars. In the second section, Paganini repeats the melody of the first section an octave higher. The piece is in the key of A, and this key allows the optimal use of the 3 bass strings of the guitar: E (dominant), A (tonic), D (subdominant). Observe the exact duration of the bass notes, and damp them by placing your thumb on the string as and where indicated by the damping symbols and finger indications on the first line.
- page 98 Delcamp, Jean-François Novelette n°3, à Alexandra
This piece is divided into two sections, like Paganini's Ghiribizzo n°24. In the first section, the melody in the bass is played by the thumb. In bars 10 and 12, to conclude the first section, I use the whole tone scale (F G A B C# D# F). In bar 16, the melody passes to the treble notes, while the thumb repeats the tonic (E) until the end. The harmonics in bar 23 are played by very lightly touching strings 1 and 3 exactly over fret XII.
- page 113 number 14, Jean-François DELCAMP (1956) GAMMES - SCALE - SCALES - ESCALAS
Scarborough Fair
Ghiribizzo n°24
Giuseppe Gasparini
Scarborough Fair
Ghiribizzo n°24
Jeremy Hickerson
Scarborough Fair
Ghiribizzo n°24
Jack Jarrett
Scarborough Fair
Ghiribizzo n°24
Michael Collings
Scarborough Fair
Ghiribizzo n°24
Elías López Cruz
Scarborough Fair
Ghiribizzo n°24
Jeremy Hickerson
Re: D04 Classical guitar lesson 04
Post by Jeremy Hickerson » Sat Dec 17, 2011 6:26 pm
Maestro Delcamp, you are correct about the therapeutic powers of Scarborough Fair - so beautifully played!
Jeremy
Robert Goodwin
Post by Robert Goodwin » Sat Dec 17, 2011 6:37 pm
Jeremy Hickerson wrote:Maestro Delcamp, you are correct about the therapeutic powers of Scarborough Fair - so beautifully played!
Hearing this soulful and moving piece reminds me of why I continue the struggle through the year two syllabus. Someday.... :casque: :merci:
Post by Jean-François Delcamp » Sat Dec 17, 2011 7:45 pm
Thank you Jeremy
Greg Johnson
Post by Greg Johnson » Wed Dec 21, 2011 6:17 am
Mr. Delcamp, your version of Scarborough Fair was indeed beautifully played. Do you happen to have fingerings readily available for playing with the capo on the 5th fret? For the notes that are too low for the capo, I am just playing them an octave higher, does that make sense? I may just work on it with open strings for now, it's going to take me a long time to get it sounding nice in the higher positions. thank you.
Jeremy Hickerson
Post by Jeremy Hickerson » Wed Dec 21, 2011 9:27 pm
Greg, you should be able to use the left hand fingerings and strings indicated in the music and just pretend the Capo fret is the nut. The only problem comes when you look at the fret board and see that you're playing a D on the high E string instead of an A as it says in the music, for instance. This is not a problem if you just go by position from the nut, i.e. think of the D as an A.
Jeremy
Greg Johnson
Post by Greg Johnson » Wed Dec 21, 2011 9:48 pm
Thanks Jeremy. Much easier that way, LOL! Still, now that I know this I can start to struggle with bringing out the melody. So this is possible to do with any piece of music? (My lack of music theory is showing here.)
Jeremy Hickerson
Post by Jeremy Hickerson » Wed Dec 21, 2011 10:56 pm
Yes, the capo just raises the pitch of the whole instrument. It's a no-brainer to understand and play if it stays in the 1st position, but when you get to higher positions sometimes it's hard to keep your bearings as to where you are in relation to the capo! Sometimes I find it easier to just remember that the A (really a D) in the bass note that begins the melody is on the 12th fret on the 4th string (i.e. ignore the relation to the capo here and just remember the absolute fret), because this is 7 frets away from the capo so it's not as easy to visualize the relationship.
Jeremy
Giuseppe Gasparini
Post by Giuseppe Gasparini » Thu Dec 22, 2011 6:19 pm
[media]https://youtu.be/fRwcXMrna68[/media]Hello, I try Scarborough Fair
Goran Penic
Post by Goran Penic » Fri Dec 23, 2011 7:23 am
:bravo: Giuseppe, very nice. :casque:
Guitar: Mirko Hotko 1989
Recorder: Olympus LS-20M
Giuseppe Gasparini
Post by Giuseppe Gasparini » Fri Dec 23, 2011 4:31 pm
Felicitations à tous les étudiants, Merry Christmas :bye: :discussion:
Michael Collings
Post by Michael Collings » Fri Dec 23, 2011 5:46 pm
Giuseppe--your Scarborough Fair is lovely! :casque:
Jeremy Hickerson
Post by Jeremy Hickerson » Fri Dec 23, 2011 8:32 pm
Guiseppe, very beautiful sound on Scarborough fair, great tone, and played with good expression!
This is a thought about interpretation: You chose a faster tempo and emphasized the arpeggio aspects of the piece, and this was very effective on the parts where you varied the arpeggio emphasis and speed.
Jeremy
Giuseppe Gasparini
Post by Giuseppe Gasparini » Fri Dec 23, 2011 10:00 pm
Thank you Jeremy and Michael, your compliments, I was touched, Greetings and happy holidays :bye: :merci: :merci: :merci:
Jeremy Hickerson
Post by Jeremy Hickerson » Fri Dec 23, 2011 10:20 pm
Happy Holidays, Giuseppe and all of you!
Here is my initial post, hopefully I'll do another and see some improvement! Scale, Scarborough Fair, Paganini, and the Novelette. I have the most trouble with the Paganin.
[media]https://youtu.be/bQQz5cXMiPY[/media]
Here are individual posts if you don't want to download the long one all at once:
Scales
[media]https://youtu.be/MtgHAREdmPo[/media]
Scarborough Fair
[media]https://youtu.be/4HHDxwKn0hg[/media]
Paganini
[media]https://youtu.be/nkPotEYzgbA[/media]
Novelette
[media]https://youtu.be/e4nVcqrhUNI[/media]
Jeremy
