D04 Classical guitar lesson 06
Post by Jean-François Delcamp » Sat Feb 11, 2012 10:22 am
Please start by downloading the new version of volume D04 that I updated today.
We are now going to work on a series of exercises:
- pages 115, 116 Delcamp, Jean-François Gammes, numéros 20, 21 et 22
Concentrate your practice on the passages highlighted in yellow, working to perfect the technique of position-shifting up and down the neck.
- page 125 Delcamp, Jean-François BARRÉ - BARRÉ - BARRÉ – CEJILLA
You have to be careful and listen to what your body is telling you when you begin to practise the barré. Be sure to keep in mind that if you overdo your practising of the barré, you risk developing tendonitis which often takes a long time to heal and will cause you a good deal of stress if, like me, you love the guitar with a passion. Pain is a warning sign that should be respected. As soon as you feel pain, you should have the wisdom to stop practising immediately until the next day. In the 80's, I wasn't prepared to listen to the pain caused by practising the barré, and only a total break from the guitar lasting a whole year enabled me to start playing again. Now I stop immediately at the first warning sign of pain. Since I started being careful, I've had no more problems.
To acquire the technique for the barré, it is essential above all not to force it. The ideal is to practise a little, but every day.
- For greater effectiveness, the thumb is placed opposite the middle finger, rather than behind the index finger making the barré.
- Place the index finger very close to the fret, almost on top of it.
- Make sure that your shoulder, forearm, wrist and hand are really relaxed. Only the fingers should be exerting a light pressure, otherwise you'll be heading for disaster and at risk of jeopardizing your future progress by giving yourself tendonitis. Relaxing the arm and forearm allows you to take advantage of the weight of the arm and forearm to help the index finger to press more easily against the strings.
- Avoid bending the left wrist, as that will hurt and will impede the action of the fingers. Find the position (of the guitar neck, your elbow and your shoulder) which will allow you to make the barré without bending your wrist.
- The creases of the finger joints cause some slight problems. In particular the crease of the joint between the last two bones of the index finger (the middle and distal phalanges).
To illustrate this, here are 2 photos of my right hand index finger ready to make a barré (I am left handed). I am not pressing on the strings, so that the crease of the joint is more visible.
1. In this photograph, the joint crease of the index finger is situated exactly over the third string, so the third string will not be pressed fully against the fingerboard, and the sound will be muffled or non-existent.
joint crease of the index finger on the 3rd string
2. A solution is to position this crease where it will not cause a problem (between the strings)
joint crease of the index finger between the 3rd and 4th strings
Practising the barré demands patience. The first results of this practice (improvement in strength) only become noticeable after several weeks or months of daily practice.
The tension of the strings (normal, hard, or extra hard) also plays a role in barrés. A set of "extra hard" tension strings requires more strength than a "normal" tension set. A "normal" tension set of strings and a low action* will help you.
* The action of a guitar is the distance between the stationary string and the frets, usually measured at the 12th fret. You can have the action adjusted by a luthier.
Finally we'll look at 4 pieces.
- page 6, 7 Milán, Don Luys Pavane I
- pages 50, 51 Sor, Fernando Exercice opus 35 n°13, en do majeur, Segovia n°2
This piece consists of a melody with accompaniment. Bring out the melody notes (those with the stem pointing up) by using rest strokes with your third finger. Play the accompaniment (the notes with the stem pointing down) quietly, with gentle free strokes using the thumb, middle and index fingers.
These two simultaneous strokes, one a strongly played rest stroke, the other a gentle free stroke, will seem very difficult, or even impossible, to achieve. But don't worry, my students manage this double stroke after 15 minutes. The first few minutes of practising this right-hand skill are always agonizing for students, because they feel that they will never succeed. In my lessons, my role is to reassure the students and encourage them to persevere. Often, after 15 minutes of repeating the same movements, students start to get there. Sometimes they are quite amazed at having succeeded at what seemed impossible. Because by repeatedly failing to perform rest and free strokes simultaneously, you end up convincing yourself that it's impossible. In short, persevere! Have courage!
Be patient, stay relaxed, don't get annoyed with yourself, don't curse me, just repeat the same movements over and over again while making an effort to get it right. In a few hours or a few days you will achieve mastery of this simultaneous rest and free stroke. This technique is used in the piece "Jeux interdits".
- page 86 Coste, Napoléon Barcarolle opus 51
Barcarolle opus 51 is in two sections, each of 16 bars. It has a phrase structure of 4 bars. The piece is in the key of A, and this key allows the optimal use of the 2 bass strings of the guitar: E (dominant), A (tonic). Observe the exact duration of the bass notes, and damp them by placing your thumb on the string as and where indicated by the damping symbols and finger indications on the first line.
- page 93 Francesco Roggi Lu primm'ammore
Barcarolle opus 51
Lu primm'ammore
Jack Jarrett
Barcarolle opus 51
Lu primm'ammore
Giuseppe Gasparini
Barcarolle opus 51
Lu primm'ammore
Jeremy Hickerson
Barcarolle opus 51
Lu primm'ammore
Elías López Cruz
Barcarolle opus 51
Lu primm'ammore
Jack Jarrett
Re: D04 Classical guitar lesson 06
Post by Jack Jarrett » Sun Feb 12, 2012 5:58 pm
I am trying to get a jump on this lesson, so here are a couple of very rough first posts
[media]https://youtu.be/TkFTKFXQnbE[/media]
[media]https://youtu.be/IcX2GKqjU7s[/media]
I cheated a little on the Sor piece as I have played it before, so it should be better.Lots of tension this morning! And the Coste piece has a looooong way to go!
Giuseppe Gasparini
Post by Giuseppe Gasparini » Mon Feb 13, 2012 4:14 pm
Bravo Jack, I put also my Barcarolle. :bye: [media]https://youtu.be/cb2PgqVVY7I[/media]
Jack Jarrett
Post by Jack Jarrett » Tue Feb 14, 2012 3:17 am
:bravo: Very nice Giuseppe!Good flow, keeping a good tempo.A trickier piece to play for me, but a few more weeks and I may just get it.
Goran Penic
Post by Goran Penic » Tue Feb 14, 2012 6:38 am
Jack and Giuseppe :bravo:
Very good first attempts. :casque:
:bye:
Guitar: Mirko Hotko 1989
Recorder: Olympus LS-20M
Jeremy Hickerson
Post by Jeremy Hickerson » Wed Feb 15, 2012 5:13 am
Jack,
Nice job on the Sor (this is one that I have played before too), and you're not far off on Barcarolle, even at this early stage. You have a beautiful tone and play very clearly. I might suggest on the Sor to play the accompaniment notes a bit more quietly than the melody.
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Wed Feb 15, 2012 5:18 am
Giuseppe,
Beautiful work on the Barcarolle, it is ready for the recording studio, I would say! Great expression, played with feeling. I hold you up as an example for how to have a very relaxed left hand, very smooth and in control.
Jeremy
Giuseppe Gasparini
Post by Giuseppe Gasparini » Fri Feb 17, 2012 5:34 pm
[media]https://youtu.be/02so318kZak[/media]Hello everyone, my Primm'Ammore :bye:
Giuseppe Gasparini
Post by Giuseppe Gasparini » Fri Feb 17, 2012 9:00 pm
Jack Goran Jeremy, :merci: :merci: :merci: :bye:
Jeremy Hickerson
Post by Jeremy Hickerson » Sat Feb 18, 2012 5:18 pm
Luys Milan Pavana
Sor Exercice
Barcarolle
Lu Primm'Ammore
[media]https://youtu.be/z0DBWyfGrRM[/media]
I forgot to practic Primm'Ammore with rest strokes, I'll work on that for the next post.
Here's an mp3 if the video takes too long to download
Last edited by Jeremy Hickerson on Sat Feb 18, 2012 6:16 pm, edited 1 time in total.
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Sat Feb 18, 2012 5:40 pm
Giuseppe,
great job on Lu Primm'Ammore - sounds real good!
Jeremy
Giuseppe Gasparini
Post by Giuseppe Gasparini » Sat Feb 18, 2012 6:07 pm
Hello Jeremy , Pavane and the Barcarolle, I find them beautiful :casque: :applauso: :applauso: :bravo: :bye:
Jack Jarrett
Post by Jack Jarrett » Sat Feb 18, 2012 8:52 pm
Jeremy :bravo: :bravo:
I echo Giuseppe! Well play pavanne fast and accurate chord changes!Good sound and feel to it!And the Barcarolle is very beautiful as well. Your talent really is showing through on this.All pieces well played!
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 19, 2012 4:34 am
Thanks Jack and Giuseppe! I like that Pavane, Segovia recorded it.
Jeremy
Jeremy Hickerson
Post by Jeremy Hickerson » Sun Feb 19, 2012 5:34 am
Check this guy out - playing Carulli on a guitar from the Romantic period
[media]https://youtu.be/MWI9EiLbFF4&feature=related[/media]
Jeremy
