Murata GR-2B Guitar Rest - a full review
Steven Joseph
Post by Steven Joseph » Thu Dec 19, 2013 9:12 pm
I recently received my 'Murata GR-2B guitar rest' from Strings By Mail and decided to share my thoughts on a guitar support which seems to be rarely seen for some reason.
I'm someone who, like many, is on an endless quest to find a way of holding the guitar that doesn't cause back/shoulder problems. I have over 15 footstools, A-frame, supports, cushions etc. which I have horded over the years in an attempt to find something that alleviates back pain AND is comfortable to play with and have so far pretty much been unsuccessful. Ironically it has been the good ole footstool that has been the best for me, but of course sitting in that position you tire quickly and its not ergonomic, but I do like the height and angle you can get the guitar that way and I'd yet to find a support that put the guitar in that position AND felt stable, until now!
I came across the Murata GR-2B through a friend's suggestion, as he was aware of my back issues and thought this would be a good solution. I'd only ever seen two guitarists using it before on Youtube - Artyom Dervoed and Grisha Goryachev, but what attracted it to me most was the angle it put the neck at, which seemed less steep than other rests dictate, something I personally prefer.
So I thought I'd do a comprehensive pros and cons list for you below. I should say I have the clamp model, not the suction cup one. I figure its much more secure and doesnt damage the polish.
Pros:
1) Comfort & Playing Position: The fact the rest only attaches to the upper bout means the lower bout can sit at a more natural and adjustable position on your right leg. A lot of other supports attach to both bouts and such it can feel like the guitar is 'levitating' and the guitar can feel quite high up, particularly the Ergoplay Troester. As for the other rests which do only attach to the upper bout such as Gitano, Dynarette etc. yes they do allow the lower bout to be lower, but unlike the Murata, the neck angle is nonadjustable.
The Murata allows you to have a very low neck angle and height if you want, something most other rests don't. It can essentially have a neck angle anywhere between parallel to ground to around 45-50deg.
2) Stability: A big must for any rest is that it must feel secure and stable whilst playing, something I feel many rests fall down on. I've given many concerts using ergoplays and gitano where I've been constantly fighting against the rest sliding down my leg, which is an unwanted distraction to say the least. I think the two biggest problems most rests have when it comes to stability are: 1) once attached, the rest becomes a solid, unadaptive structure, meaning as you sway and tilt whilst playing, the contact point between it and your leg is constantly changing size and position, which leads to slipping. 2) most rests contact your leg via a small strip of fabric going horizontally across the thigh, meaning the resistance against the rest moving side to side on the leg is good, but it is poor for stopping it moving up and down the leg, which is a much bigger issue for me. Perhaps the biggest plus for the Murata then is that it addresses both these issues brilliantly. The rest contacts your leg with a nicely shaped 'saddle', which sits on the leg well, covers a good surface area, has an excellent grippy fabric and most importantly sits lengthways on the leg, stopping it sliding away. Also, the metal support connects to the leg pad via a hinge joint, which means you can rock back and forth whilst playing and the contact area of the leg pad remains the same.
And of course, the four leg clamp unit is as stable and secure as you could ask for with no damage to the polish.
3) Quality: Of all the devices I've seen and used, this is by far the most exquisitely constructed. Like most Japanese products, the engineering and quality of materials is excellent. From the choice of metal to the gripping fabric on the leg rest to the joints, hinges and screws, you can really detect the attention to detail and a well thought out design. I often get the feeling with some other rests they were made by the lowest bidder (the gitano and dynarette in particular) and that they are very overpriced for what they are and whilst the Murata is by no means cheap, for what you get $74 is very reasonable. Also you wont need to fork out for new suction cups when the old ones wear out!
4) Portability: The Murata is extremely portable due to its clever design. As the support rod is detachable from the clamp unit and the leg rest is on a hinge, it can be folded right down so it is flat and will fit in most guitar cases. This is again another plus against many of its rivals, which are bulky and awkward to carry around at times.
Cons:
1) Limitations: I found a couple of issues in regards to max height and neck angles. Im fairly tall (6'3'') and I have the Murata set to its absolute maximum height. Although Im comfortable, I fear that if I was forced to play on a taller chair I would need something to prop my left foot up slightly so it didnt feel too low, but this is obviously only going to be an issue for taller players.
Though I mentioned earlier one of its plus points being its ability to have a low neck angle, its downside is the opposite in that its not possible to get a steep neck angle. So if you like your guitar to have a steep playing angle this isnt for you.
2) Aesthetics: To be honest, I dont like the look of most supports, and compared to many I've seen the Murata isn't too bad, but it still looks a little bit like scaffolding to me! I personally prefer my rests to be as discreet as possible and perhaps it would have been better if it was all black, just so it drew as little attention to itself as possible, though it would be hard for anyone to miss the big clamp on the guitar!
3) Adjust-ability: This isn't so much of a con as perhaps an area for further improvements. Essentially only 3 things are adjustable: the height of the support rod (and hence the angle of the neck), the angle between the rest and your leg (via forward/backward moving hinge joint) and the placement of the clamp on the guitar (which adjusts its position to your body from side to side and also the neck angle somewhat). I wish there were a few more moveable joints and hinges just to give it that extra level of adjust-ability. I find the fact that the joint where the support rod meets the clamp is fixed at 90deg very annoying, as it means you have to adjust your legs/the position of the leg rest to get certain angles. I also think a 360deg ball & socket joint attaching the leg pad to the support rod would be an improvement, giving more flexibility and dimension for you to move in, instead of restricting you to backwards or forwards.
Overall I'm very pleased and impressed with this rest and for what I'm looking for its probably the best one on the market. I've also experienced little to no back pain whilst playing whilst using it, which is more than can be said for my other devices so it looks promising thus far!
many thanks
Steven Joseph
Professional guitarist, composer and performer.
petemeyersguitar
Re: Murata GR-2B Guitar Rest - a full review
Post by petemeyersguitar » Thu Dec 19, 2013 11:38 pm
I've used mine for several years now and it's been a great option for me; I'll never go back to anything with suction cups. You're right in that it isn't the prettiest thing in the world, but I feel like its one of the least visually intrusive from an audience perspective.
Supperconductor
Post by Supperconductor » Sat Dec 21, 2013 5:32 am
Steven,
Thanks for that comprehensive write up! I've read that the Murata is not suitable for guitars with a raised fretboard. That's why I've tried pretty much everything else, but not the Murata. Do you have any thoughts on this?
Currently I'm using the A-Frame MI (Multi-Instrument) model, which attaches via suction cups to the back of the guitar and therefore avoids the issue with guitars that have raised fretboards (and consequently tapered tops/decreasing shoulder width).
- Kam
2012 Hippner Hauser SP/IR
[Savarez Corum 500R Normal Basses
La Bella RN-L Rectified Nylon Light Trebles]
Post by petermc61 » Sat Dec 21, 2013 5:44 am
Steven
A very comprehensive review, the most comprehensive I have seen to date on a support. I have considered the Murata before but never quite understood it so have not taken the plunge.
I have one question which arises because I have too many guitars. How long would it take to swap it between different instruments? I am assuming you need to adjust for different body thicknesses for the clamps but not too many other adjustments as the player and the chair are the same? So, changeover complexity and time?
Regards
Peter
Steven Joseph
Post by Steven Joseph » Sat Dec 21, 2013 10:14 am
Supperconductor wrote:Steven,
I cant see why it wouldnt work if im honest. The guitar effectively 'sits' or is held by the whole clamp unit, then you tighten the four prongs to the back and sides of the guitar for extra security. Depending on the severity of your guitar's tapering it may be the case that the two prongs nearest the neck arent actually able to touch the guitar, but the back two certainly would and that I imagine would be more than enough for stability. Again though, I can't say this for sure as obviously its designed to clamp on to an object that is all the same width.
Peter
petermc61 wrote:Steven
Regards
Peter
Its actually not bad at all. In fact its probably less of a faff than getting off a bunch of suction cups as all you have to do is loosen then the clamp tightening screw, which takes about 2 seconds, remove it, attach it again and re-tighten. Probably wouldnt take more than 10 seconds. Adjusting the height is also very simple and much simpler than on an Ergoplay for example, as again its simply a case of loosening a screw a bit, sliding the pole up or down and re-tightening.
Another dimension I forgot to mention in the review is the ability to rotate the leg pad clockwise/anticlockwise to sit on your leg more comfortably. In other words, you dont need your left leg to point straight out perpendicular from your body to have the guitar sitting square across your body. You can have your left leg point out as much as you like and twist the pad so it sits square on your thigh without the guitar having to be twisted to the left as well, which is very good for ergonomics and another plus point and proof of the importance i placed on devices having non-fixed parts.
As I said in the review one of the downsides of most other rests such as gitano, dynarette, ergoplay etc. is once attached they are fixed so where they go, the guitar must follow. If I want to sit naturally with my legs pointing slightly away from each other, to get an ergoplay square on my lap I have to twist my torso to the left - not so with the Murata.
Steven Joseph
Post by petermc61 » Sat Dec 21, 2013 10:18 am
Thanks for that update Steven. I think I will have to try it. I got a large Dynarette but my leg has a slight downward slope and the Dynarette just does not feel secure. I end up raising my heel to stop it slipping - which is worse ergonomically than a foot stool!
Steven Joseph
Post by Steven Joseph » Sat Dec 21, 2013 10:29 am
petermc61 wrote:Thanks for that update Steven. I think I will have to try it. I got a large Dynarette but my leg has a slight downward slope and the Dynarette just does not feel secure. I end up raising my heel to stop it slipping - which is worse ergonomically than a foot stool!
Oh yes its much better than dynarette believe me and it allows you to put it in a very similar, if not better, position than the dynarette with the ability to adjust many angles. The gripping fabric on the leg rest is the best I've come across as well. Much better than ergoplay and miles better than that joke of a fat felt strip on Dynarette, which only serves to destabilise it and ironically make it feel very wobbly on your leg!
Steven Joseph
Pierre Tremblay
Composer
Post by Pierre Tremblay » Sat Dec 21, 2013 1:01 pm
HI!
I join my voice to those saying that it is a very nice review.
I use myself a Murata and I have both parts: the one with suction cups and the other that is a clamp. I prefer so far the clamp one for the stability (and I can confirm it works ok with an elevated fingerboard).
Guitars: Patrick Mailloux double-top (spruce on top, cedar)
Supperconductor
Post by Supperconductor » Sat Dec 21, 2013 6:45 pm
Steven & Pierre,
Thanks for the responses. Looks like I'll be adding to my collection of supports. I'll let you all know how it works out.
:merci:
EDIT: Regarding the max height issue, I saw this note in the description on the String by Mail product page:
Note: The elevation pole that comes shipped with this Murata is 3" in length. It can replaced with a custom shaft on our Guitar Support Parts page.
- Kam
Steven Joseph
Post by Steven Joseph » Sat Dec 21, 2013 7:00 pm
Ah nice spot, I may have to order that then. Better too much height available than too little! Thats one of my cons removed as well then!
Steven Joseph
FHC
Post by FHC » Sat Dec 21, 2013 7:48 pm
Steven Joseph wrote:Ah nice spot, I may have to order that then. Better too much height available than too little! Thats one of my cons removed as well then!
Love mine. I did get the additional height rod.
Renlab
Post by Renlab » Thu Dec 26, 2013 11:44 pm
Just got mine today. The instructions came in Japanese (I think)
Is there a front and back to this thing?
From the illustrations I think the clamp adjustment "screw" points to the back? (That is a question lol)
blackbrook
Post by blackbrook » Sat Feb 06, 2016 12:20 am
I just got one of these and I also wish that the angle with the top clamp were adjustable. It's working for me, but by only clamping two of the feet to my guitar rather than all 4 (to support an unusual posture), but it still seems secure enough.
As to its neck angle and max height limitations, you can buy longer replacement rods to increase this. The rod that comes with it is 3 inches, and there are several larger sizes. I'm using an 8 1/4" rod for quite a steep neck angle.
I'm debating bending the rod to customize the clamp angle.
Post by ronjazz » Sat Feb 06, 2016 6:39 pm
A $14 strap works even better, especially if you adjust it while using your footstool, after which you can sell your footstool for $14.
keithwwk
Post by keithwwk » Sun Mar 13, 2016 12:05 pm
I have one too and customized few different lengths metal rob. After I concentrate and practise regularly some simple yoga postures the mutara is collecting dust now.
Antonio Picado Model 60 Spruce 2017
Esteve Mod 1.4ST Spruce 2003
Ryoji Matsuoka M20 Cedar 1978
M.Sakurai No.5 Cedar 1976
Yamaha G225
