D02 Classical guitar lesson 08
Post by Jean-François Delcamp » Fri Feb 28, 2014 8:29 am
Please start by downloading the latest version of volume D02.
First we will study some technical exercises from volume D02.
- page 77 Jean-François DELCAMP (1956) GAMMES - SCALE - SCALES – ESCALAS
When changes of position are needed, you will be using the "position shift" technique. The position shift involves moving the left hand along the neck, from position to position, from fret to fret. Position shifts are shown by oblique lines linking two fingering indications given for the same finger.
Concentrate your practice on the passages highlighted in yellow, and do your best to perfect the position shift technique.
- page 80 Jean-François DELCAMP (1956) LIAISONS - LEGATURE - SLURS - LIGADOS
Ascending slurs are produced by striking (hammering down on) the string with a left hand finger. The faster and more decisive this movement is, the more volume is obtained. Practise particularly on the nylon (unwound) strings, as these are the most difficult to get a clear sound from.
- page 82 number 34 Jean-François DELCAMP (1956) ARPÈGES - ARPEGGI - ARPEGGIOS – ARPEGIOS
- page 86 6/ Improvise using only 6 notes (D E G A B C) for 20'.
Next we'll work on five pieces :
- page 35 Johann-Philipp KRIEGER (1652-1735) MENUET
- page 37 Henry PURCELL (1659-1695) MENUET Z. 649
http://en.wikipedia.org/wiki/Hemiola
The Tarentela and the 2 Villanos are played using strums with the index finger. The arrows indicate the direction of the strum. In the strum, several strings are struck in rapid succession, to give the effect of a chord, that is to say of notes played simultaneously.
- page 43 Gaspar SANZ (1640-1710) LA TARENTELA
In bars 1, 2, 4, 5 and 8 the thumb rests on the 6th string. In bars 3, 6 and 7 the thumb rests on the 5th string. It is important not to move the hand while the index finger moves up and down. Resting the thumb on a bass string helps to keep the hand still. It also prevents the accidental sounding of one or more bass strings that are not used in certain chords.
http://en.wikipedia.org/wiki/Tarantella
- page 49 Gaspar SANZ (1640-1710) 2 VILLANOS
2 Villanos: While the index finger is playing the strums, the thumb rests on the 5th string. Except when the chord of A major is being played, where the thumb rests on the 6th string.
- page 80 number 25 Jean-François DELCAMP (1956) LIAISONS - LEGATURE - SLURS - LIGADOS
KRIEGER MENUET
LA TARENTELA
Haris Karachristianidis
KRIEGER MENUET
LA TARENTELA
Laura Staats
KRIEGER MENUET
LA TARENTELA
Satyajit Kadle
KRIEGER MENUET
LA TARENTELA
Halil Akaydin
KRIEGER MENUET
LA TARENTELA
CarlWestman
KRIEGER MENUET
LA TARENTELA
Re: D02 Classical guitar lesson 08
Post by Haris Karachristianidis » Fri Feb 28, 2014 6:34 pm
In Krieger Minuet in measures eg 6 and 7 we keep the notes till the ----- lines finish? So in measure 6 sol will last 2/4 instead of 1/4? Thank you.
Post by Marko Räsänen » Fri Feb 28, 2014 6:49 pm
Haris Karachristianidis wrote:In Krieger Minuet in measures eg 6 and 7 we keep the notes till the ----- lines finish? So in measure 6 sol will last 2/4 instead of 1/4? Thank you.
Those lines indicate the hemiolas. The durations of the notes don't change, only the accentuation. Normally when the time signature is 3/4 you would emphasize the first beat of each bar slightly. But now instead of emphasizing the the notes occurring at the first beat of bars 6 and 7, you emphasize the first and the third beats of bar 6, and the second beat of bar 7. So in effect you play those two bars as if it was three bars with the time signature changed into 2/4.
So instead of: BEAT, beat, beat | BEAT, beat, beat
you play: BEAT, beat, BEAT | beat, BEAT, beat
Hopefully my explanation makes sense :bye:
Alhambra 4P spruce
Almansa 457 cedar
Cordoba C12 spruce
Laura Staats
Post by Laura Staats » Fri Feb 28, 2014 7:26 pm
Thanks Marko. I was wondering what those markings meant.
Post by Haris Karachristianidis » Fri Feb 28, 2014 10:20 pm
Thanks Marko. Your reply was very helpful.
Halil Akaydin
Post by Halil Akaydin » Sat Mar 01, 2014 12:12 pm
Hi, has anyone been able to figure out the trill being used in measure 7 of the Johann-Philipp KRIEGER MENUET. I can't seen to figure out what's being played.
Mariano Martínez Gallego
Post by Mariano Martínez Gallego » Sat Mar 01, 2014 5:08 pm
D01. Symbols
"--------" indicate that the fingers of the left hand are not lifted but remain in place on the fingerboard.
Un saludo
Mariano.
"-------" indican que los dedos de la mano izquierda se mantienen sobre el diapasón.
Mi paso más
Post by Marko Räsänen » Sat Mar 01, 2014 5:16 pm
Hi Halil, it's a cross-string trill, and it's played like this:
1) p plays 'e' on the 4th string, and at the same time a plays 'c' on the 2nd string.
2) i plays 'b' on the 3rd string (4th fret)
3) m plays 'c' on the 2nd string
4) p plays 'b' on the 3rd string (4th fret)
The notes are played in very rapid succession, which is why finger alternation must be used. Naturally all the notes are being let ring which eachother, which creates a harpsichord-like effect. It's an advanced technique, way beyond the 2nd year, so don't feel bad if you can't make it sound like professor Delcamp does.
Alhambra 4P spruce
Almansa 457 cedar
Cordoba C12 spruce
Post by Marko Räsänen » Sat Mar 01, 2014 5:28 pm
Mariano Martínez Gallego wrote:D01. Symbols
Hi Mariano,
That is the case when the dashed line connects two notes of the same pitch, as in 'La Tête Bizarde' (D01 page 14; bars 23-24). When the dashed line is used above the staff to group notes together, it means a hemiola.
Alhambra 4P spruce
Almansa 457 cedar
Cordoba C12 spruce
Stefan Srećković
Post by Stefan Srećković » Sat Mar 01, 2014 5:29 pm
Here's a brief explanation on a cross-string trill.
[media]https://youtu.be/xY24R4rNMwE[/media]
Halil Akaydin
Post by Halil Akaydin » Sat Mar 01, 2014 6:03 pm
Marko and Stefan :merci:
Post by Marko Räsänen » Sat Mar 01, 2014 7:17 pm
Really good find, Stefan!
Many of the things he talks about generalize well into arpeggio playing as such :merci:
Alhambra 4P spruce
Almansa 457 cedar
Cordoba C12 spruce
Stefan Srećković
Post by Stefan Srećković » Sat Mar 01, 2014 7:26 pm
He's a solid teacher, infrequent videos though, can't blame him.
LindaWoodford
Post by LindaWoodford » Sat Mar 01, 2014 8:43 pm
Hey thanks guys for this really interesting discussion. I've been trying to do one of these cross string trills without any clue as to how to go about it (or indeed knowing that it had a name!) Suffice to say that I wasn't very successful.
Anyway, the explanation and video are very helpful, so hopefully I'll do a better job next time!
Regards, Linda
Post by Mariano Martínez Gallego » Sat Mar 01, 2014 10:32 pm
Hi Mariano,
yes Marko, O.K. :bye:
Mariano
Mi paso más
